Model t rear axle: Cad or detailed drawings
Davey1916
First Name: Cameron
Last Name: Davey
Post by Davey1916 » Mon Dec 02, 2019 11:55 pm
Hey all, I'm after a cad file or someone that has sketched up a detailed drawing for the rear drive axles. The only thing I have close to either is the image i've attached which I found on here.
Many thanks for any help
Cam from DownUnder
MTFCA Number: 16175
MTFCI Number: 14758
Re: Model t rear axle: Cad or detailed drawings
Post by Steve Jelf » Tue Dec 03, 2019 12:10 am
Davey1916
First Name: Cameron
Last Name: Davey
Post by Davey1916 » Tue Dec 03, 2019 1:34 am
Thanks Steve unfortunately I'm after dimensions ect. But those drawings sure are cool!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Dec 04, 2019 1:45 am
That drawing you have is pretty basic, and obviously lacks much needed tolerances. An interesting method of defining the taper across the entire length of the axle too... IIRC, it’s 3/4” per foot with centerline taper, can’t help you with gauge diameter, but know you need to keep pretty tight tolerance on the taper to maintain overall axle length
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Dec 04, 2019 1:22 pm
Just use the Ford Service book. You don't need drawings.
Post by TRDxB2 » Wed Dec 04, 2019 3:19 pm
Here is a link with an additional picture for cutting the key way
http://www.mtfca.com/discus/messages/50 ... 1231423423
