Using the original generator in a 12v car?
Posted: Thu Dec 05, 2019 9:15 pm
Greetings.
My '23 Model T was converted by the previous owner to 12 volts, with a single coil and distributor. It still has the stock Generator and cutout, which he says he never got the chance to regulate so as to charge sufficiently for 12 volts. I see that Langs and several others carry a replacement cutout specially designed for a 12 volt conversion ( https://www.modeltford.com/item/T12CK.aspx ), but it is backordered both in Langs and every other catalogue I can find. Is this voltage regulator necessary to using the original 12 volt system, or can the original cutout be used? If so, how would one best adjust the original generator to charge the 12v battery correctly?[image][/image]
