Obscure speedster trivia 2...?
Posted: Sat Dec 07, 2019 10:15 pm
by Kevin Pharis
Since the last go around was solved in just 30 minutes...
Anybody recognize this gear set?
Re: Obscure speedster trivia 2...?
Posted: Sat Dec 07, 2019 10:37 pm
by Steve Hughes
Distributor gears.
Posted: Sat Dec 07, 2019 11:57 pm
by dobro1956
Atwater Kent ??
Posted: Sun Dec 08, 2019 12:08 am
by TonyB
I agree with distributor gears, the lower one on camshaft and the other on the dizzy.
Posted: Sun Dec 08, 2019 12:19 am
by Kevin Pharis
Distributor gears.
Getting warmer... but which one?
Atwater Kent ??
Not this one
Posted: Sun Dec 08, 2019 2:39 am
Delco? With all the different distributors made for the Model T this could be a real challenge. It's not Bosch.
Posted: Sun Dec 08, 2019 1:09 pm
by Kevin Pharis
Not Delco... and it’s supposed to be a challenge! ;)
While not Bosch either... this accessory did come outfitted with a Bosch distributor as an option...?
Posted: Sun Dec 08, 2019 3:47 pm
by AndyClary
Probably drive gears for a triple plate.
Andy
Posted: Sun Dec 08, 2019 4:41 pm
Texas T distributor
Posted: Sun Dec 08, 2019 4:54 pm
by Kevin Pharis
Andy
You got it!!
Here are a couple original Tri-Unit ads showing the timer elevator, and the Bosch option
Posted: Sun Dec 08, 2019 6:53 pm
by Kevin Pharis
Here is a pic of the inner workings...
Posted: Sun Dec 08, 2019 7:36 pm
by Michael Peternell
Now that is a 🍑!!! If you're into accessorie kind of things!
