A-B-C Electric Start Adapter, Getting it to work
Topic author - Posts: 5339
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I took this project on as the Gentleman was at an end. No one could do it, odd armature, twisted, etc. I like a challenge anyway, keeps your brain from becoming mush.
These are rare ducks in my opinion as I have seen ones similar but this one is a Cadillac. I am posting this to maybe help another.
The problem is the armature is shot, the fields and brushes have been messed with and it is an odd size. What to do to make it work? Huuuummmmm!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: A-B-C Electric Start Adapter, Getting it to work
So after some measuring and calculating, why can I not adapt a Model T Ford guts to fit?
Let the machining begin.....,
Well, after some cleaning up and making the case true, (This thing was made from cast steel not iron. And anyone out there that has done old cast steel knows, BEWARE) Nice and slow on material removal, and watch out for voids and hard spots. The T armature was the easy part, but making that rear brush holder fit was a slow go. The original field blocks were formed into the case so taking them down to the dimensions of a Ford case was needed. That was it for a few days, will post more progress later.
- First Name: Herb
- Last Name: Iffrig
Very interesting. Thank you for letting us see that. I tke it that it is an accessory electric starter for an early Model T. Why do you say it is a Cadillac?
- MTFCA Number: 4838
- MTFCI Number: 115
Herb
Hank likely used that term due to the adv. copy of the A-B-C system.
"Puts Ford starting in the same class with the highest priced cars"
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Herb it appears this Model was the refine version of previous models. Unique mechanisms. There was an optional attachment that went on the crank pulley for a generator. Neat how things progressed.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Some added repairs. This Epoxy is for panel attachment in modern vehicles but man is it strong. I have fused items together that there really was not any other way. The lower mount had a bunch of micro fractures and she was welded before. I noticed little voids here and there so to support it, formed a piece of 1/16" steel plate and epoxied it on. I previously machined the case to accommodate the added dimensions.
- First Name: Les
- Last Name: Schubert
Remember, it was Cadillac automobile that introduced the world to the first practical electric self starter in 1912.
This was likely a very early adaption for the Ford. Note, the ad shared by Dan T was October '17, and although a not quite accurate artist's conception, the car pictured is likely also a '17.
The ad also states that the ABC is a "two unit" device. That means a separate starter motor and generator. In the parlance of the day, a "single" unit such device would have used a single housing and armature wired so that with a simple switching it would perform both the starting and the generating.
From the pictures posted so far, it looks like this might be a single unit device? I can't really tell, because most single unit devices used much larger motors in those days.
Similar starter setups were manufactured by several companies for Fords for several years after 1912. They evolved quite a bit over those few years, and I have seen pictures of a number of them. This one looks quite nice!
Fantastic repair workmanship Hank !
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Hank, You continue to prove there is more than one way to solve a problem.
As a machinist for most of 60 years, I'd super glue the broken parts together and put the parts on my tracing mill and make a copy in steel.
Your solution and fabricating skills are so simple and great.
- First Name: David
- Last Name: Carnahan
- * REQUIRED* Type and Year of Model Ts owned: 1917 Speedster
- MTFCA Number: 49550
watch "Mr. Wizard"!
...some people are like Slinkies....they're generally useless but fun to watch when you push them down the stairs.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
After all the final machine work and insulating, a quick pre-fit went well. It is a little tight as far as clearances/access but will work. This application requires a CW rotation as viewed from the rear of the case, no problem, North and South reversal by means of changing attachment of the feed post and brushes. You have to do the same thing if any of you are converting to 12 volts using a field coil from a 1956-1996 Ford starter.
Coating the fields.
Cut down Model T armature.
Checking the spacing.
Coating the fields.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
After machining the new bearings, reset thrust, assembly went better than a text book. Operation check and load test..., PERFECT!
Will wait for my graphic artist to return from vacation and he is making me a new tag.
Hope this can assist some of you in your projects in overcoming obstacles.
All the Best,
All the Best,
