Replacing lower steering column bracket bushing
Posted: Fri Dec 13, 2019 4:07 pm
by Tmodelt
I have never changed one, but I am looking for the "dos / don'ts and how tos". Any help / advice would be greatly appreciated. This is on a RHD. I would think that the bushings would be the same? Thanks in advance.
Re: Replacing lower steering column bracket bushing
Posted: Fri Dec 13, 2019 4:38 pm
Rather easy to do that job.
For some hints, this article covers most of them.
https://nebula.wsimg.com/b97f8efd9b7fba ... 31FDB20580
Posted: Fri Dec 13, 2019 4:39 pm
Early cars used 2 bushings - later to '25 used one - '26 - '27 used a different size - what year bracket you replacing ?
Posted: Fri Dec 13, 2019 5:35 pm
by Russ T Fender
Easy enough to do unless the steering shaft itself is worn. If that is the case the shaft may need to be replaced or turned down to the diameter where the shaft is worn. Otherwise, if you ream the bushing so you can get the shaft in the bracket it will be loose when the part of the shaft that is worn is in the bushing.
Posted: Fri Dec 13, 2019 6:01 pm
do not fail to finally, install a felt "seal" at the top of the housing to slow the loss of grease when the grease cup is turned down. I do not see that in the article Dan referenced.
Posted: Fri Dec 13, 2019 6:48 pm
by Tmodelt
I have no idea as to the year. I haven't taken old bushing out yet and was planning on buying both sizes. The outside diameter appears to be the same and I haven't checked the steering column diameter either. Many thanks.
Posted: Fri Dec 13, 2019 7:10 pm
steering shaft diameter is the same on all
OD of 09-25 is 1" and those years use two bushings
OD of 26-26 is 7/8" and those years use one bushing
should be easy enough to check without having to order extra bushings. I understand it's RHD, but it really isn't that hard to tell years apart, is it? Improved cars are considerably different from earlier cars...
Posted: Sat Dec 14, 2019 10:36 am
Contrary to what Steve mentioned, the early cars used one bushing, the same length as the bracket.
Posted: Sat Dec 14, 2019 11:53 am
I stand corrected Larry - I've replaced early bracket bushing with 2 as the single is not available - this CRS is getting troublesome !
Posted: Sat Dec 14, 2019 12:25 pm
I was technically wrong, 09 to about 14/15 used one long bushing, and then they went to two shorter bushings (26-27 uses different, single bushing). Even so, I do not believe that anyone is selling the "correct" bushing for 09-15, and like Steve said, the double/shorter bushings work just fine. The correct bushing can be no doubt purchased from any bearing supplier. A cast bronze bushing would be what you want, and then be sure to drill for the grease fitting post-install...and again, remember to put in the felt seal after reaming, and prior to sliding the steering shaft in
Posted: Sat Dec 14, 2019 1:48 pm
by Tmodelt
Thanks again. I am attempting to build a RHD speedster. I have most of the big cast pieces located, but will try to fabricate the smaller pieces.
Posted: Sat Dec 14, 2019 1:50 pm
by Tmodelt
In previous post, I forgot to mention that this is a project built with parts and pieces scrounged out of my vineyard and garage attic. No particular year except for drive train.
Posted: Sat Dec 14, 2019 3:51 pm
Does it look like any of these LHD. The one on the far right of the top picture is 26-27
