u-joint wear
Posted: Sat Dec 14, 2019 12:04 am
by donald4ham
How much wear is too much on a u-joint before it is worn out?
Re: u-joint wear
Posted: Sat Dec 14, 2019 1:41 am
by Kerry
By Ford specs, if more than .006" it's scrap.
Re: u-joint wear
Posted: Sat Dec 14, 2019 10:26 am
Don't forget to pack the u joint area with a light grease.
Re: u-joint wear
Posted: Sat Dec 14, 2019 1:47 pm
by Pep C Strebeck
Kerry wrote: ↑Sat Dec 14, 2019 1:41 am
Frank is right on; Ford Model T Service, paragraph 591, "
If there is over 0.006" clearance between knuckles and rings a new universal joint should be installed."
The rear axle booklet that is published by the MTFCA on page 17 says "
The four bearings should also be tight with no more than 0.010 - 0.020 inch clearance."
While doing the most recent rear axle overhaul I was fortunate enough to have a N.O.S. Ford universal joint and the clearance was 0.0025" to 0.003" depending on which trunion/knuckle you would check. There is quite a discrepancy between the Ford specification and the MTFCA booklet, 0.006" versus 0.010" to 0.020" of clearance. If anyone has a new replacement/reproduction universal joint on hand, I would definitely be interested in knowing what the new manufacture ones are coming in at.
And Larry is right, don't forget to pack the u-joint bell at the front of the driveshaft housing, prior to re-installation. After I would run a newly installed u-joint (rebuilt rear axle) for a little bit, I would always add some more grease. The spinning and centrifugal force will spin out some of the grease and create a void in and around the u-joint, pack it back through the grease cup.
