Where to buy copper rings
Topic author - Posts: 987
- Last Name: Gould
Where can I buy a few sets of copper manifold crush rings in bulk. I'd like about three sets. I see the vendors sell the rings and glands in sets but I want the copper rings only. I am not interested in the type that are shaped to enter the manifold and block. Just the ordinary copper rings.
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Re: Where to buy copper rings
I bought mine from aircraft spruce.
- MTFCA Number: 52564
The suppliers sell just the rings.
https://www.modeltford.com/item/3063.aspx
1920 Dodge touring
1920 Dodge touring
- First Name: Bill
- Last Name: Austen
I second Aircraft Spruce I got them there for one of my Model N's
https://www.aircraftspruce.com
- MTFCA Number: 16175
- MTFCI Number: 14758
If they're out of stock at all the Model T parts dealers, here's another place to look:
http://www.gen-aircraft-hardware.com/
- First Name: Les
- Last Name: Gitts
- * REQUIRED* Type and Year of Model Ts owned: '11 Torpedo, '13 Towncar, '22 Centerdoor
You can also get them from Olson's Gaskets
www.olsongaskets.com
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
You can get them from any auto parts store. They were used on VW's.
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
I'd like to add something that may be useful. Aircraft spruce sells AN hardware meant for aircraft that may have applications on our Model T's. Cotter pins, copper gaskets, safety wire, etc. Of special interest are the bolts and nuts. They are fine thread such as is found in our T's and you can get them with heads or shanks drilled for safety wire or cotter pins. Castle nuts of high or low profile are also available. True, such bolts may not be "correct" for a T but sometimes there are applications where their special configurations might be just the ticket.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Try contacting Lang's, sometimes they either have partial sets or are willing to break up a set to get you just the part(s) you need.
- Last Name: Gould
Thanks for all the responses. Plenty of suppliers to choose from.
- Last Name: Hanlon
- MTFCA Number: 50191
I got my last set without gland rings from FATMAN, Bob’s antique auto parts...
Call Chaffins
1920 Dodge touring
1920 Dodge touring
