Dubatt's crank
Posted: Tue Dec 24, 2019 3:42 pm
by Joe Bell
I had not installed one in several years but I have to say it sure is nice not having to deal with grinding or cutting the horse shoe for the inspection pan, that tad more clearance is great!
Re: Dubatt's crank
Posted: Tue Dec 24, 2019 9:04 pm
by Kerry
I wish that scat would shave a bit off the diameter, would make life a lot easier to fit :D
Re: Dubatt's crank
Posted: Tue Dec 24, 2019 9:18 pm
by Walter Higgins
Are there any interference issues with a Scat in a one-piece pan?
Re: Dubatt's crank
Posted: Tue Dec 24, 2019 11:44 pm
by Joe Bell
Walter, never done one so I can not answer that one on the one peice pan???
Re: Dubatt's crank
Posted: Wed Dec 25, 2019 12:30 am
by DJPeterson
No clearance problems with the Scat crank installed in my Canadian 26 Foredoor last year.
Re: Dubatt's crank
Posted: Wed Dec 25, 2019 12:53 am
by Kerry
I,m surprised at that Dale.
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 12:57 am
by Kohnke Rebabbitting
We never had a problems with all the Scat cranks we put in. About 78 to date.
The only thing that could make some off, is if the line bore Guy didn't know how to line bore, and get them always off center.
Herm.
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 1:18 am
by Kerry
Herm, sounds like out of 78 scats you never had to fit any of the pans :D
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 7:22 am
by Joe Bell
Kerry, I was thinking the same thing, I for got once and bolted it on, found out real quick when I turned it over the first time!
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 4:14 pm
We use 26-27 pans, in all engines!
Herm.
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 6:06 pm
by It's Bill
So Herm, if a guy had an early engine and wanted to keep all the visible stuff original to the year in question, you couldn't help him out? You would not build with an early pan? Question asked with the greatest respect, Bill
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 7:40 pm
I have never had that come up. Normally, after I explain the advantages of a 4 Dip, that's what they want. But if they don't, normally again, they don't want anything, but a Ford crank. If we do use the 26-27 pan, they keep their original pan, with the car.
I know all you Guys Grind the Horse shoes, but i take it off the crank, I just don't like to refit the good parts to the problem parts.
We used to build counter, weighted cranks for the Model A's, the O. D. is the same. Here is a picture of our crank.
Herm.
Re: Dubatt's crank
Posted: Thu Dec 26, 2019 11:01 pm
by SurfCityGene
I have a DuBats crank in my '12 with an early pan and would not ever change it out for a later one! That Narrow nose adds a minimum of 2 miles per hour!
