New rings
Posted: Tue Jan 29, 2019 8:57 pm
My car had some blow by and smoking so I decided to
Put in a new set of rings. I am at standard bore with cast iron pistons. All of the vendors were out of standard
Rings so I ordered .010 over and gapped them to .012.
I started it up and got smoke out of the crank case once it got hot then the motor was tight. I have it back apart
No dAmage was done. Should I gap the rings wider or
Wait for Grant to make some standard rings. Philip
