Columbo cross drive magneto questions
Posted: Fri Dec 27, 2019 12:12 am
Im getting ready to install the Columbo cross drive magneto on the speedster project engine. There is a small mystery hole on the inside of the casting where the shaft is located. The hole is beside the slightly larger oil hole for the shaft. The mystery hole is threaded and I can see no use for it. ?? The large cam gear also runs very close to the inside of the casting so there really is no room for something to bolt there.
I searched past threads about Columbo mags and found one more pic of a threaded hole in the same location as my mystery hole. I also found a few photos showing the inside of the casting with just a single hole for oil to the shaft. The second picture (grey casting) shows a single hole. The shaft is visable thru the threaded mystery hole and is smooth. There are no groves that could be used to control end play with. Also the design of the shaft controls all the end play.
I contacted Dan McEachern about the mystery hole. He is the person who makes the new gears for the Columbo. He did not know what it was for. So I guess Ill just ignore it and move on, unless someone knows what its for .....
Any input will be appreciated. After 35 plus years of messing with model Ts, this is my first external magneto to install. Im learning as I go ...
