23 model t touring head light reflectors
Topic author - Posts: 107
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
- MTFCA Number: 50661
Head light reflectors need to be cleaned, Rust film very little , finger prints how do i clean look,s like a delicate plating
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Re: 23 model t touring head light reflectors
Reflectors are silver plated. If the plating is intact, they will clean up like a mirror with silver polish.
- MTFCA Number: 4838
- MTFCI Number: 115
Rubbing with silver polish, try to not rub in circles as that affects the reflective image.
- First Name: Daniel
- Last Name: Jensen
- MTFCA Number: 31955
If you plan on driving your car at night, the new reflectors available from the vendors with the vacuum metalized aluminum coating work very well and do not need polishing. Snyders also now sells headlight bulbs that the filaments are horizontal when installed. This makes it possible to properly focus the headlight beam.
1923 Touring low radiator
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
An object lesson. The left reflector is an original silvered one in tolerable shape. The right reflector is one of the aluminum coated ones from Lang's. It's a world of difference, and I'll know in a few days how much difference it'll make. And of course, check that you have good grounds.
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Buddy...if you’d like to sell the used one on the left, I’d be interested in it.BuddyTheRoadster wrote: ↑Thu Jan 02, 2020 3:03 amAn object lesson. The left reflector is an original silvered one in tolerable shape. The right reflector is one of the aluminum coated ones from Lang's. It's a world of difference, and I'll know in a few days how much difference it'll make. And of course, check that you have good grounds.
It matches my decent reflector and I don’t drive my car at night.
1924 Touring
