23 model t touring head light reflectors
Posted: Fri Dec 27, 2019 8:09 am
by Rich Huggins
Head light reflectors need to be cleaned, Rust film very little , finger prints how do i clean look,s like a delicate plating
Re: 23 model t touring head light reflectors
Posted: Fri Dec 27, 2019 8:22 am
by Humblej
Reflectors are silver plated. If the plating is intact, they will clean up like a mirror with silver polish.
Posted: Fri Dec 27, 2019 9:20 am
Rubbing with silver polish, try to not rub in circles as that affects the reflective image.
Posted: Fri Dec 27, 2019 8:17 pm
by Dan_Jensen
If you plan on driving your car at night, the new reflectors available from the vendors with the vacuum metalized aluminum coating work very well and do not need polishing. Snyders also now sells headlight bulbs that the filaments are horizontal when installed. This makes it possible to properly focus the headlight beam.
Posted: Thu Jan 02, 2020 3:03 am
by BuddyTheRoadster
An object lesson. The left reflector is an original silvered one in tolerable shape. The right reflector is one of the aluminum coated ones from Lang's. It's a world of difference, and I'll know in a few days how much difference it'll make. And of course, check that you have good grounds.
Posted: Thu Jan 02, 2020 9:04 am
by RustyFords
BuddyTheRoadster wrote: ↑Thu Jan 02, 2020 3:03 am
Buddy...if you’d like to sell the used one on the left, I’d be interested in it.
It matches my decent reflector and I don’t drive my car at night.
