13 pinnion gear
Posted: Mon Dec 30, 2019 1:32 pm
by Rich Huggins
high gear ratio 13 tooth pinnion install on 40 tooth stock ring gear can i do it 1923 t touring 3speed bg warnner t 90 trans
Re: 13 pinnion gear
Posted: Mon Dec 30, 2019 1:46 pm
by Ruxstel24
You can use a 40 tooth gear with a 13 tooth pinion, but not a stock ring gear.
It has to be recessed on the backside to position it to the left a little, to be able to get the proper depth of the pinion. 3.076 is the ratio.
Re: 13 pinnion gear
Posted: Tue Dec 31, 2019 3:42 am
by Rich Huggins
Were do i find the proper ring gear 40 tooth with recess
