Conductive lubricants vs non-conductive (dielectric) lubricants
Posted: Wed Jan 01, 2020 11:27 am
Happy 2020 everyone. I would like to start a conversation here regarding electrical conductive lubricants, vs non-conductive (di-electric) lubricants. I have been on the forum for 20 years (since 2000) and though there may have been discussions on this, I have never seen it brought up and, from what I have read on it, it may be a very important topic to discuss here.
Since starting a thread a couple of days ago, asking for the best way to lubricate the old roller type timers, I have done some online reading into this and have come to the realization that only dielectric lubricants should be used to lubricate electrical components such as distributors, generators and timers. Lubricants, such as graphite grease and white lithium grease and other metal laden lubricants, which conduct electricity and therefore could cause a short or burn out the unit, especially on components such as the Model T timers in which the outer contact surfaces are so close, the grease can bridge the gap and therefore cause major problems in the proper function of the timer. Conductive lubricants can be used on contacts such as prongs and battery terminals and in places where there is no danger of the positive and negative contact surfaces or surfaces that must be kept separate such as the four timer contacts, intermingling or coming into contact with eachother, but on the Model T timers, especially, I would question their use and use only dielectric lubricants on the timers. I did an image search and saw where dielectric lubricants are sold in tubes, specifically labeled “dielectric” grease or lubricant for use in lubricating electrical components.
I would also ask if there are metal laden motor oils or additives that are meant to be used in the crank cases of modern cars but should be avoided at all cost for use in the crankcase of the Model T due to the magneto inside and the danger it could pose by converting the oil into a highly conducive solution.
I know we have a lot of electrical experts on the forum and I am the first to admit that electricity is my weakest subject that I understand the least, so I would welcome a discussion on this topic so we can all learn more about what could be an important subject in the proper function of a crucial component in our T’s. I look forward to your input. Thank you. Jim Patrick
