Super is ready
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
- MTFCA Number: 295
- MTFCI Number: 127
Super is ready
A little heat helps installation.
- Last Name: Warren
Re: Super is ready
Soup is on, Yes it does give you one good shot! What's Momma say about it ?
- Last Name: Osterman
Re: Super is ready
My soup is usually brass parts in ketchup
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
Re: Super is ready
Cook 1 part ,freeze the other,makes things fit easier.
- MTFCA Number: 16175
- MTFCI Number: 14758
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Super is ready
Some of the newer modern transmissions have a press-fit on internal bearing to shaft fit. A special fixture is needed for disassembly and you use heat transfer plugs for assembly.
Plugs are heated to 450F degrees, usually on a hot plate and then put inside the bearings for a few minutes and everything slides together with ease. Without doing this you can break the cases...
- Attachments
- 7D9D6EB6-3E77-481E-B3DB-2856ABCE87F9.jpeg (27.26 KiB) Viewed 6259 times
- CE4E5ACA-E026-4499-93FB-9D0DCF959030.gif (12.75 KiB) Viewed 6259 times
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Super is ready
Steve, it's Zahnradsuppe!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Super is ready
Looks like gearlosh for supper
Re: Super is ready
It's not Model T, so I was thinking maybe some other make or pre-T Ford.
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
- MTFCA Number: 8082
Re: Super is ready
Looks to be the clutch disc drum from the turbo 400 clutch disc setup in Lang's catalog
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Super is ready
Turbo 400 clutch disk.
Now cooking 26/27 tail shafts in lye water
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Re: Super is ready
There is no Momma, so he can cook whatever he wants. Inside or out.
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
- First Name: Keith
- Last Name: Gumbinger
- MTFCA Number: 4661
- MTFCI Number: 6866
Re: Super is ready
Dean, Could you please tell us why you use lye water instead of regular water to cook the '26 - '27 tailshafts?
Thanks,
Keith
Thanks,
Keith
Re: Super is ready
For flaor of course! Thats no lye
Re: Super is ready
Flavor!!!
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Super is ready
Lye to de grease and removes rust.
Very caustic do outside !
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: Super is ready
Always use eye cover, my father years ago showed me a guy with a white eye from getting lye in it, that made me remember every time!!
