Super is ready
Posted: Fri Jan 03, 2020 8:39 pm
by D.Yoder
A little heat helps installation.
Re: Super is ready
Posted: Fri Jan 03, 2020 8:43 pm
by John Warren
Soup is on, Yes it does give you one good shot! What's Momma say about it ?
Re: Super is ready
Posted: Sat Jan 04, 2020 9:02 am
by Mark Osterman
My soup is usually brass parts in ketchup
Re: Super is ready
Posted: Sat Jan 04, 2020 9:22 am
by tdump
Cook 1 part ,freeze the other,makes things fit easier.
Re: Super is ready
Posted: Sat Jan 04, 2020 9:45 am
by Steve Jelf
What is it?
Re: Super is ready
Posted: Sat Jan 04, 2020 9:53 am
by Ruxstel24
Some of the newer modern transmissions have a press-fit on internal bearing to shaft fit. A special fixture is needed for disassembly and you use heat transfer plugs for assembly.
Plugs are heated to 450F degrees, usually on a hot plate and then put inside the bearings for a few minutes and everything slides together with ease. Without doing this you can break the cases...
Re: Super is ready
Posted: Sat Jan 04, 2020 10:09 am
by TWrenn
Steve, it's Zahnradsuppe!
Re: Super is ready
Posted: Sat Jan 04, 2020 10:11 am
by Dallas Landers
Looks like gearlosh for supper
Re: Super is ready
Posted: Sat Jan 04, 2020 10:49 am
by Steve Jelf
It's not Model T, so I was thinking maybe some other make or pre-T Ford.
Re: Super is ready
Posted: Sat Jan 04, 2020 11:24 am
by old_charley
Looks to be the clutch disc drum from the turbo 400 clutch disc setup in Lang's catalog
Re: Super is ready
Posted: Sat Jan 04, 2020 11:57 am
by D.Yoder
Turbo 400 clutch disk.
Now cooking 26/27 tail shafts in lye water
Re: Super is ready
Posted: Sat Jan 04, 2020 12:09 pm
by DHort
There is no Momma, so he can cook whatever he wants. Inside or out.
Re: Super is ready
Posted: Sat Jan 04, 2020 12:15 pm
by D.Yoder
- Turbo400
Re: Super is ready
Posted: Sat Jan 04, 2020 12:39 pm
by KeithG
Dean, Could you please tell us why you use lye water instead of regular water to cook the '26 - '27 tailshafts?
Thanks,
Keith
Re: Super is ready
Posted: Sat Jan 04, 2020 12:45 pm
by Dallas Landers
For flaor of course! Thats no lye
Re: Super is ready
Posted: Sat Jan 04, 2020 12:46 pm
by Dallas Landers
Flavor!!!
Re: Super is ready
Posted: Sat Jan 04, 2020 1:39 pm
by D.Yoder
Lye to de grease and removes rust.
Very caustic do outside !
Re: Super is ready
Posted: Sat Jan 04, 2020 3:15 pm
by Joe Bell
Always use eye cover, my father years ago showed me a guy with a white eye from getting lye in it, that made me remember every time!!
