New tool
Posted: Mon Jan 06, 2020 4:55 pm
by D.Yoder
Out of 7 output shafts 4 had loose r404F477D20A2ABC2.jpeg[/attachment]
- Rivet removing anvil
Re: New tool
Posted: Mon Jan 06, 2020 5:12 pm
by Joe Bell
And they are usually the 26-7 ones!
Re: New tool
Posted: Mon Jan 06, 2020 5:47 pm
by D.Yoder
They were all 26/27 . Why do they fail? Wider brake bands??
Re: New tool
Posted: Mon Jan 06, 2020 7:14 pm
by Dan Hatch
Dean: What I have been finding is that if the rivets are not loose then the driven plate will be cracked. Does not matter if wide or narrow.
I think it has to do with 4th main alignment. Pan straightness.
Re: New tool
Posted: Sun Jan 12, 2020 10:07 am
by Jim Eubanks
I had the same problem and had a hard time finding a replacement, finally got one off ebay. I am tempted to re rivit the old one and weld it.
Re: New tool
Posted: Sun Jan 12, 2020 1:31 pm
by D.Yoder
I just received oversized rivets. I will drill and er rivet should be better than new.
Re: New tool
Posted: Sun Jan 12, 2020 1:50 pm
by Les Schubert
The problem you are talking about is why I developed the “floating transmission shaft “. It significantly reduces the loads.
Dan Hatch is who I have licensed to make it.
