Transmission safety wire
Wilbur
First Name: Wilbur
Last Name: Swearingin
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout 1923 Coupe 1924 Tudor 1926 Pickup
MTFCA Number: 24971
MTFCI Number: 20989
Post by Wilbur » Tue Jan 07, 2020 9:03 am
Helping a friend with a nice TT truck. Doing primary inspection noticed someone in remote past safety wired transmission with stranded copper. Well it probably long ago broke and was hanging loose. Pulled it out with my fingers. Has anyone tried putting the safety wire in through the trans door. Looks like should be able to. Any advice would be welcome.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Transmission safety wire
Post by RajoRacer » Tue Jan 07, 2020 11:38 am
Are you referring to the driven plate bolt(s) wire ?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jan 07, 2020 12:48 pm
The only hardware you can reach thru the transmission inspection cover is the 6 driven plate bolts, and the clutch finger screws.
The driven plate bolts can be wired thru the cover (suggest wiring in pairs). The clutch finger screws take cotter pins, and also can be done thru the access cover
Wilbur
First Name: Wilbur
MTFCA Number: 24971
MTFCI Number: 20989
Post by Wilbur » Tue Jan 07, 2020 2:42 pm
Yes the driven plate bolts. Plan to wire together in pairs.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Tue Jan 07, 2020 4:23 pm
After they've been checked for tightness, right? :)
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Wed Jan 08, 2020 6:04 am
You could ask your wifes gyneacologist to do it :lol:
Leo van Stirum, Netherlands
Post by Scott_Conger » Wed Jan 08, 2020 5:32 pm
Would like to see how he'd get it up on the table...
NH Full Flow Float Valves
