26 gas tank
Ed Donnelly
First Name: Ed
Last Name: Donnelly
MTFCA Number: 32160
26 gas tank
Post by Ed Donnelly » Thu Jan 09, 2020 4:51 pm
Need a source for 26 gas tank weld in inlet fitting. I'm replacing several anf need help.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: 26 gas tank
Post by Humblej » Thu Jan 09, 2020 5:15 pm
No new sources, you will have to salvage from another tank.
jbond
First Name: Herb
Last Name: Spies
MTFCA Number: 29830
Re: 26 gas tank
Post by jbond » Thu Jan 09, 2020 6:56 pm
I got a used but excellent 27 tank from :
http://bobsantiqueautoparts.com/
Wash out a few dead mice and it was good to go.
Ed Donnelly
First Name: Ed
Last Name: Donnelly
MTFCA Number: 32160
Re: 26 gas tank
Post by Ed Donnelly » Thu Jan 09, 2020 10:17 pm
Well the suppliers are getting newtanks for 09's -27 from somebody. I'm sure mfg. Overseas, but the weld in fittings are what I'm needing.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: 26 gas tank
Post by Ruxstel24 » Thu Jan 09, 2020 10:35 pm
I have a pretty decent original tank....
MTFCA Number: 14972
MTFCI Number: 15411
Re: 26 gas tank
Post by RajoRacer » Thu Jan 09, 2020 10:36 pm
Actually Ed, the gas tanks are made in the U.S. - bad news is no one is reproducing '26-'27 cowl tanks !
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Re: 26 gas tank
Post by John.Zibell » Thu Jan 09, 2020 10:38 pm
As far as I know, no one is making 26/27 cowl fuel tanks. So no new production of the fitting the sediment bowl goes into. You could salvage one from a bad tank, or fabricate your own. The thread is 1/2 inch pipe thread. You would have to make up some type of collar to fit the pipe thread piece to the tank. The metal is thin, so the part would have to be soldered or brazed to the tank.
1926 Tudor
Ed Donnelly
First Name: Ed
Last Name: Donnelly
MTFCA Number: 32160
Re: 26 gas tank
Post by Ed Donnelly » Fri Jan 10, 2020 8:53 am
Hey Steve, who is the manufacturer of the 25 and earlier tanks? They too will work and yes they are soldered.
MTFCA Number: 14972
MTFCI Number: 15411
Re: 26 gas tank
Post by RajoRacer » Fri Jan 10, 2020 10:42 am
I don't have his name but he's in Arkansas, I believe - Donnie Brown knows him & he's on here - maybe he can supply it.
Re: 26 gas tank
Post by TRDxB2 » Fri Jan 10, 2020 10:47 am
I don't know if there are differences in the '26 gas tank inlet looks like but this is from an earlier tank. It was soldered in. Something I can part with.
Ed Donnelly
First Name: Ed
Last Name: Donnelly
MTFCA Number: 32160
Re: 26 gas tank
Post by Ed Donnelly » Sat Jan 11, 2020 11:31 am
Thank, but I'm looking for a quantity supplier so I may do local repairs.
