1927 Touring-replace front windshield rubber
Posted: Sun Jan 12, 2020 10:59 am
by BMonoModelTFord
Just got a full rubber replacement kit for front windshield for 1927 Touring.
Is there any wise information or tricks to the replacement?
Re: 1927 Touring-replace front windshield rubber
Posted: Sun Jan 12, 2020 11:06 am
by CudaMan
On my 1924, the gasket between the cowl and the base of the lower windshield frame kept slipping out of place during installation, so I taped it down in a few strategic places with blue masking tape first. Once the windshield frame was in place, I was able to pull the masking tape out, leaving the gasket.
On the side seals for the upper windshield frame, I used a few dabs of black silicone sealant to help retain the seals in their slots. I let the silicone harden completely before putting any pressure on the seals. :)
Posted: Sun Jan 12, 2020 11:10 am
by BMonoModelTFord
Thank you, I like the idea of the tape, great idea
Posted: Mon Jan 13, 2020 1:49 pm
by EricMac
When I restored my 26 Touring I also used black silicone to hold the gaskets in place. Don't worry, the windshield will continue to leak like yoy would expect!
Posted: Mon Jan 13, 2020 1:55 pm
by BMonoModelTFord
Thanks Eric
Do I need to remove the glass or is it possible to slide along track on lower and upper glass
