Top mounting body irons runabout 1925
Topic author - Posts: 4957
- MTFCA Number: 52564
Which of these would be correct for 1925 runabout? Long ones or short ones? At some point I am going to add a top to my 25 cutdown pickup.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 1219
Re: Top mounting body irons runabout 1925
See if this helps any.
http://www.mtfca.com/discus/messages/29/20560.html
This may be a good one too.
http://www.mtfca.com/discus/messages/25 ... 1338403545
Or not?
Hope you figure it out.
Or not?
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
The bottom hole of the bracket is bolted to the body using one of the door latch bolts. Look or measure to see which bracket has a lower hole that lines up with the door latch.
Rich thanks for the link, LOL got more lost reading it as seems the posters did too, they are all over the place,.
CudaMan, I will check that out. When and if the upholster gets put on no one will see it anyway.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 121
- MTFCI Number: 16310
The point here is, do it right! I don't recall if the bolt lines up with the upper or lower striker plate hole, but make sure you are using the correct two hole striker plate, as opposed to the four hole one which is earlier.
