Top mounting body irons runabout 1925
Posted: Sun Jan 12, 2020 5:26 pm
Which of these would be correct for 1925 runabout? Long ones or short ones? At some point I am going to add a top to my 25 cutdown pickup.
Re: Top mounting body irons runabout 1925
Posted: Sun Jan 12, 2020 6:47 pm
by Rich Eagle
Posted: Sun Jan 12, 2020 7:08 pm
by CudaMan
The bottom hole of the bracket is bolted to the body using one of the door latch bolts. Look or measure to see which bracket has a lower hole that lines up with the door latch.
Posted: Mon Jan 13, 2020 12:22 am
Rich thanks for the link, LOL got more lost reading it as seems the posters did too, they are all over the place,.
CudaMan, I will check that out. When and if the upholster gets put on
no one will see it anyway.
Posted: Mon Jan 13, 2020 11:44 am
The point here is, do it right! I don't recall if the bolt lines up with the upper or lower striker plate hole, but make sure you are using the correct two hole striker plate, as opposed to the four hole one which is earlier.
