Garage Exhaust Hose
MadMax
First Name: Max
Last Name: Lindsay
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 21 Runabout
Garage Exhaust Hose
Post by MadMax » Mon Jan 13, 2020 3:13 pm
Howdy all! This is a side topic, but since I’ll be using it with my T, I guess it’s fair game.
I’d like to buy an exhaust hose to run my T in the garage without being gassed to death by the old lady. I see Dayco high temp semi-flexible hoses, but not sure of the size I’d need and if I’d need adapters.
Does anyone use one of these to get the fumes, soot, and Model T ‘emissions’ out of a closed garage? If you do, any suggestions of brand, size, and adapters?
Thanks in advance!
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Re: Garage Exhaust Hose
Post by varmint » Mon Jan 13, 2020 4:04 pm
Depends on which muffler you have installed. If it includes a tail pipe then you can just measure it but if the muffler has a oblong hole then the device will have to wrap around the entire muffler. Don't forget about leaks at the muffler bearing (the other end).
Don't expect many to reply to what hose to use as you are taking your life in your own hands.
Vern (Vieux Carre)
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Mon Jan 13, 2020 7:30 pm
I got mine years ago from McMaster-Carr. I don't remember exactly what type it is but this stuff looks like it would work. Heat resistant to 500 degrees and it runs about $10/ft. Their part number for it is 55125K73.
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Mon Jan 13, 2020 10:57 pm
Excellent point, Varmint! Hadn’t thought about leaks. CO isn’t a snake to be toyed with!
RV, thanks for the suggestion. I was looking at this stuff on Amazon:
Dayco 63530 Garage Exhaust Hose https://www.amazon.com/dp/B001O4S26U/re ... hEbD9KD1XZ
Something tells me it’s the same stuff as in M-C. Any thoughts on sealing to keep gasses from building in the garage? I would likely still have fresh air coming in as well a CO detector just in case.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Mon Jan 13, 2020 11:21 pm
If you don't have fresh air coming in then it will create a partial vacuum, kinda like a diesel submarine momentarily running under water.
Winter time we have a kerosene heater running and have to operate it with the door open. The heat and exhaust escape through big vents in the roof, not efficient but at least it's warm and safe.
Vern (Vieux Carre)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jan 13, 2020 11:41 pm
I would put some kind of fan on the outside end to suck the exhaust outside.
HPetrino
First Name: Henry
Last Name: Petrino
* REQUIRED* Type and Year of Model Ts owned: 1918 TT
Post by HPetrino » Tue Jan 14, 2020 9:02 am
Lot's of good points here. We built a bus repair facility once years ago. We installed an exhaust evacuation system that included a fan at the building wall which basically pulled a vacuum on the hose system. This prevented any exhaust gas from escaping into the room. Also a part of the system was a large spring loaded damper to provide barometric relief. As a vacuum was created in the room it allowed fresh replacement air in. All in all it worked very well even when there were 2 or 3 large diesel bus engines being run at the same time. Of course, with that much air moving in and out it's pretty hard to keep the shop warm.
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Tue Jan 14, 2020 3:22 pm
Today i feel inspired with dumb ideas but would a shop vacuum work with extra hose in and out?? Portable would also be nice for welding? :D Bud :D
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Tue Jan 14, 2020 4:06 pm
I think a fan or maybe a shop vac would help.
It all depends on how long you plan on running a car, how much ventilation you have, etc.
I have a shop that I work on cars for a living in.
I just run a hose through a hole in my garage door with a flap over it. My garage is far from air tight though... I have a piece of PVC that fits inside the hose nicely and I stick it out the door.
But again, I’m not running anything for more than 5-10 minutes usually.
Max, I have an extra hose that is too small in diameter for modern stuff. You want it, pay shipping and it’s yours. (I think I still have it)
Email me if you want it.
TLeroux
Last Name: Leroux
MTFCA Number: 20412
Board Member Since: 2010
Post by TLeroux » Tue Jan 14, 2020 9:46 pm
look up SVI international on the net they sell this hose for auto shops
have any trouble let me know
tom 714-412-3200
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Fordor
Post by Kenny Edmondson » Tue Jan 14, 2020 10:07 pm
I use a Harbor Freight dust collector to vent my sandblaster to the outside. It would work well for exhaust fumes also.
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Wed Jan 15, 2020 8:49 am
More excellent ideas! I was wondering if the shop vac may overheat? Hmm....
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Wed Jan 15, 2020 10:12 am
Easy to try and they are like something else,everyone has one? Whatever you use can a meter be found to check air quality? :D Bud. :D
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Thu Jan 16, 2020 7:32 pm
Hey Bud,
I was thinking exactly that. The company that made my security system has a carbon monoxide detector they sell. I’m thinking about getting that out just one from Lowe’s or Amazon.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
MTFCA Number: 25079
MTFCI Number: 18732
Post by TFan » Thu Jan 16, 2020 11:30 pm
When I replaced my c/o detector I put the old one in the garage, everything was hunky dory till I fired up the T then all he-double hockey sticks broke loose. Found out real quick that that old one still worked. BOY are they loud. Jim
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Fri Jan 17, 2020 12:03 pm
Hahaha! Something tells me it didn’t take much or am I wrong?
That’s been a thought swimming around in my head - how much CO would get into the garage still even with the hose out the door (and possibly hooked into a shop-vac)? At the same time, I’m guessing the heat radiated from the engine and exhaust would require a window to be open and a fan to pull/push air in/out.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Fri Jan 17, 2020 3:49 pm
Here’s the set up I use for the sandblaster, saw dust vacuum etc. should work for exhaust fumes as well.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Jan 17, 2020 7:11 pm
I have a beautiful original high temp rubber flex hose 2 3/4” ID X 12’ long. Anybody interested, $60.00 plus shipping. Would not want buy new.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sat Jan 18, 2020 1:18 am
I have 2 exhaust hoses in PVC pipe under my floor. I used 2 gas meter bases with cast iron covers. I just lift of the cover and pull the hose out of the floor. The PVC pipes join together and come up out of the ground out side with a turn down. I do not have a fan on it. If I did it again I would come up indoors and put a fan in and then out through the wall, or ceiling. It works fine as along as you don't run something too long.
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Sat Jan 18, 2020 2:30 pm
That's a really cool idea, Scott. Unfortunately, I'd have to chip up my cement to do that! Ha ha ha.
Many thanks about the offer on the hose, Hank, but I've already just gotten one. Much appreciated.
I'm really liking idea of the shop vac! Something that hit me though... If you were running too rich, would you risk the possibility of ignition when the gas fumes get near that motor while it is running? I'm NOT an electrical person, so I have no clue how independent the air flow is from the motor with a shop vac.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Sat Jan 18, 2020 3:13 pm
Your concern about unintended ignition is a valid concern. Rich exhaust is combustible. I personally would never use something (like a shop vac) that's not rated for combustibles in the application being discussed here. Way too much can go wrong.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sat Jan 18, 2020 4:01 pm
Forget the shop vac idea. Just running the hose out side will do fine. The old filling stations had a hole in the door with a little cover to run the hose out side. Unless you need to run it a long distance. If so, get a small squirrel cage type fan and adapt the hose to it. Then run some duct work, piping, or more hose out side. The fumes will not come into contact with the motor. You are not wanting to collect the fumes, you are wanting to exhaust them out side.
Dave Frost
Last Name: Frost
* REQUIRED* Type and Year of Model Ts owned: Unfinished 26 RPU and 26 Coupe
Post by Dave Frost » Sat Jan 18, 2020 4:09 pm
Guy in my neighborhood thought it would be a good idea to siphon gas with a shop vac. The fireball and fire was amazing. Burnt to the ground.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Sat Jan 18, 2020 5:33 pm
Dave,
Thanks for posting your comment. That's exactly the kind of thing I'm talking about. Sometimes I'm flabbergasted at things folks try. Kinda scary.
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Sun Jan 19, 2020 6:22 pm
Yowza! Hmmm.... maaaaaybe if it’s far enough in the back yaaaaaaard???.... nahhhhh! I think I’ll pass. The mushroom cloud would be cool, but I don’t think my neighbors would be amused. Hahaha.
Seriously, thanks for the input on this. I’m a little nuts, but I’m not crazy. Intuition was working.
As the old saying goes, “a stopped clock is right twice a day”...
One down, one to go!!! :D :D :D
MadMax
First Name: Max
Last Name: Lindsay
Post by MadMax » Tue Jan 28, 2020 6:45 pm
Just dropping a big "thank you" to Dave Hanlon! After I got home from an extended weekend ski trip, I found a boxed up 10 foot hose to use.
Many thanks again, Dave! Have a great week!
