model B Ford update
Topic author - Posts: 1249
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
model B Ford update
The 1904 model B Ford project has taken longer then i thought it would. Back when this car last ran it had only low gear and was one running on one cylinder. So, its taken a while to discover and sort out all the issues. The motor is done, the ignition is still a bit cranky, but that should get sorted out this week. The transmission is all over the work bench, most of the new parts are made, im still waiting on one new fiber spacer. The transmission suffered from a few badly worn parts, some incorrectly repaired parts from back in the day, and one part was just plane wrong. Most of the knowledgeable people on model B Fords have passed away and they left little written knowledge behind. I got lucky and found most of the original B drawings at the Bensen Ford research center. That allowed me to get all the worn transmission parts accurately reproduced. Im hoping for completion by May of this year.
- First Name: Kim
- First Name: Kim
Re: model B Ford update
The gear reduction motor works great to turn the fairly tight motor over at 32 RPM.
- First Name: Rob
- Last Name: Heyen
Kim, looks like it’s coming along great! Thank you for the update.
- First Name: Kim
This is the high speed cone that the clutch fingers ride on. I don’t know where the old one came from. But as you can see, it’s different from the new correct one.
Looking better and better!
Do we get to know who owns this car now? I guess the reason I am curious (beyond the I like to know who has some of the more interesting cars?), is that I can see you are putting a lot of time, effort, and doubtless money into this project! While there would be a lot of personal satisfaction working on such a rare and significant piece of automotive history, I do hope there is more than that in it for you!
It would be incredible if this car could be taken to the London to Brighten Veteran Car Run! Its provenance should be no problem for the pre-'05 qualification.
- MTFCA Number: 1219
- First Name: Bill
- Last Name: Austen
- * REQUIRED* Type and Year of Model Ts owned: 1915
Back in the early 70's I worked for Ed Towe in Montana, we had a heck of a time getting his Model B running. Most of his engine was done by Wil Faulstick, which may have been the problem. The car did run.? I hope you have better luck.
Austen
Austen
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Don Tyler in Amsten Ohio has a Model B that was his father's car years back, he rebuilds the early Fords and other early car engines, so maybe this may helps you on some thing. Joe
- First Name: Rob
- Last Name: Heyen
Joe, Don has his dad’s early Ford and its a great running car. However, it’s a Model C. There are only a handful of Bs remaining, and I don’t know of any running at the moment. The one at THF was running a few years ago, but I believe the transmission is in need of repair.
Rob
Rob
Hey there Bill Austen! I remember Wil Faulstick talking about working on that model B for Ed Towe. As I recall, he said the car was an intact survivor car in the early '50s, when a previous owner sent the engine out to a machine shop to be rebuilt. Somehow, the original engine was lost by the shop, likely sent out as junk. So Ed Towe got the car as a decent and solid original car with no engine (if I recall correctly?). Wil said he pretty much built the engine from scratch, using copies of Ford's original drawings that had come from the Ford archives. This, well before the archives became the Benson Library. I did get to see the model B, with its hood open showing Wil Faulstick's beautiful workmanship at the Towe Museum in Sacramento Califunny about 25 years ago. I also was fortunate to be able to meet Ed Towe on a VMCCA Nickel Age tour in 2006. I think it was one of the last major tours he drove a car on.
Wil Faulstick was an incredible machinist! He literally could make almost anything! Quite a few members of the Bay Area Horseless Carriage Club got cars back on the road because of his skills at repairing the unrepairable.
I wonder who has that model B now?
- First Name: Bill
- Last Name: Austen
Wayne, The Towe B is owned by a well known member of the Early Ford Registry here in California. I own a model N ford that Wil had and restored. He sold it to Broadway Motors in Oakland years before I got it.
Austen
Austen
- First Name: Kim
Interesting info Bill and Wayne, I've seen that B at the sac auto museum a couple of times. I got permission from the owner to remove the floor boards and take pictures. It helped a lot in determining my transmission issues. I am fortunate that the car I'm working on has most of its correct original parts. I was particularly concerned about the original radiator. One trip to the radiator shop has made it leak free! I've heard the same story about the engine in the Sac B car, it's a great looking car, well worth a visit to the Sac museum. There are also 2 model K Fords there.
- First Name: Rob
- Last Name: Heyen
Kim, an interesting side note to the K roadster (of the two you wrote about). It was purchased new in Omaha, and escorted the German entry part of the way across Nebraska during the 1908 NY to Paris race. It is also the K that was shipped to England in the 50’s for the English Anglo tour. It’s a well travelled Ford.
- Last Name: Carter
- * REQUIRED* Type and Year of Model Ts owned: 1913, 1919, 1924
- MTFCA Number: 28125
- MTFCI Number: 21824
I'm sure there are a lot of others like me that appreciate the info and pictures. Please keep them coming.
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
- Last Name: Nunn
- MTFCA Number: 50321
Where is the Sac Museum? There is a SAC (Strategic Air Command) Museum in Nebraska but that has military aircraft.
- First Name: Bill
- Last Name: Austen
The California Automobile Museum
2200 Front St, Sacramento, CA 95818-1107
Was originally the "Towe" Ford Collection
- First Name: Kim
The transmission is now back together. There has to be a certain amount of clearance in the transmission so it rotates freely. The clearance is set by the nut on the end with the set screw. Any ideas on what this clearance should be? In thinking .025-.030?
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Lewis Rector did a lot of work on that Model B when Towe first got it and brought it to the shop in Helena for him to assemble. I saw it several times and did a very very small part in helping Lewis with it a couple times.
Are you familiar with Wayland Henry in Oregon. He reproduced at least one and probably more B engines. Keith from Gresham knows him well.
Kim, what would the B have had for an original carburetor??
- MTFCA Number: 16175
- MTFCI Number: 14758
I think I understand most of what I see there, but what's the story on the copper tubes coming out of the firewall?
- First Name: Kim
Stan, Wayland owns this car. He hasn't done much transmission work so he doesn't know the answer to the clearance issue. The B used 3 different carbs. Schebler, Holley and Kingston. I found a letter in the archives dated 1904 stating that all 3 carbs had been tested. The Holley was the best performer. The 1904 Holley is similar to the one used on the A and AC cars. the 1904 is a bit larger and has a few different internal parts. I have one but it still requires alot of fixing. I set up the NH to get the car started and and other running issues sorted out before i put the 1904 Holley on.
Steve, the brass tank is an oil reservoir pressurized by exhaust gas. Oil is fed up to a valve block where drip rates are set. one for each cylinder and one for the transmission ball cap.
- First Name: Stan
- Last Name: Howe
I have some early holleys that are different than what I've seen..if you can send me a photo or drawing I may have one.
- MTFCA Number: 24868
KimDobbins wrote: ↑Sat Jan 18, 2020 3:54 pmStan, Wayland owns this car. He hasn't done much transmission work so he doesn't know the answer to the clearance issue. The B used 3 different carbs. Schebler, Holley and Kingston. I found a letter in the archives dated 1904 stating that all 3 carbs had been tested. The Holley was the best performer. The 1904 Holley is similar to the one used on the A and AC cars. the 1904 is a bit larger and has a few different internal parts. I have one but it still requires alot of fixing. I set up the NH to get the car started and and other running issues sorted out before i put the 1904 Holley on.
Kim,
The Early Ford Registry has Gene Kristoffy's drawings for the "B" Holley carburetor. He made one, (or more), from scratch for the complete "B" engine/s he manufactured many years ago.
- First Name: Kim
Thanks Jerry, I made most of the missing parts off those drawings. There is still a fair amount of work to do on the carb.
- First Name: Kim
- First Name: Stan
- Last Name: Howe
Wish I had a couple of those but they are different than what I have.
Depending on the actual design, needle and seat is a pretty small problem.
Kris would be pleased! What a guy he was...KimDobbins wrote: ↑Sat Jan 18, 2020 6:28 pmThanks Jerry, I made most of the missing parts off those drawings. There is still a fair amount of work to do on the carb.
- Last Name: Warren
What a monumental task Kim, Looking great! Thanks for sharing.
- First Name: Rob
- Last Name: Heyen
Kim,
I’m excited to see and hear your project run and drive. The Model B is the rarest, and I suspect least known of the alphabet Fords. I also suspect it was a strong car for the money in 1905. Thank you for including us as you bring this important piece of history back to life.
- First Name: Kim
Today we made another attempt to get the 1904 model B Ford running. After a little work on the distributer, #3 is again firing. After turning the motor over a few times, I choked it and ran all 4 cylinders through the cycle. Then turned on the ignition, pulled down the spark lever a few notches and the motor took off! We only ran it a minute or so but it sounded real good. Sure was good to hear it run good, it may have been 100 years since it was last run. Maybe Rob can post the video of the motor running.
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
- First Name: Gary
- Last Name: Como
- MTFCA Number: 49625
I can only imagine the feeling of satisfaction from reviving such a piece of history.
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
From either side that is a beautiful engine.
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Saw Jim's video on FB and love it. Awesome to see history come back to life.
[attachment=0]IMG_20190614_093020_01.jpg[/attachment]
Closest I'll ever get to a model B.
- First Name: Rob
- Last Name: Heyen
Congrats Kim! You guys are doing wonderful work on this piece of Ford history!
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Wow. I'm in awe of you guys who revive this historic machinery.
1924 Touring
