Is my model T seized up?
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Fri Jan 17, 2020 9:23 pm
Hey everyone! My name is Carson I am 12 and just bought a 1924 model T touring. It was my dream car! I know its a little early, but it was a good deal and I took advantage and picked it up in California and took it back to Las Vegas. It is all restored and I was driving in circles around my backyard practicing and I parked it to go eat breakfast but when I came back, tuned on the key, stepped on the starter button and nothing happened, so I tried the crank and the engine did not budge. It has oil, so I am confused. Would you all help me please?
jab35
Last Name: Bartsch
MTFCA Number: 30615
Re: Is my model T seized up?
Post by jab35 » Fri Jan 17, 2020 9:34 pm
Carson: Welcome to the Forum. I think engine seizure is unlikely. Are you sure you don't have the car parked in gear, hand lever fully forward? If parked in neutral, the clutch could be jammed ( which I think is unlikely) jacking up one rear wheel and turning crank would help identify that, crank, engine and wheel will rotate. You will get at least 10 responses with advice in next hour, so you won't lack for info. Good luck and happy model T'ing. jb
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Fri Jan 17, 2020 9:54 pm
This forum is so cool! I have tried pushing the car in neutral, and it rolls, so I think the clutch is not stuck. Thanks for your help!
John Warren
Last Name: Warren
Post by John Warren » Fri Jan 17, 2020 10:05 pm
Carson, Like mentioned, it may be in gear, It sounds like you know what makes it go, so you should know where neutral is, 1/2 to all the way back on the emergency brake lever. You may have had the linkage come undone between the clutch peddle and the clutch, next I have had the starter bind up engaged. If this is what it is ,put the emergency brake lever all the way forward ( high gear) and push the car backward, sometimes this will unbind it. We are having breakfast at Pegs diner on West Sahara at 8:30 ish. in the morning. You can call me any time, I can come over and help you figure it out. 353-4436 Congratulations on the purchase.
Tim Williams
Last Name: Williams
Post by Tim Williams » Fri Jan 17, 2020 10:08 pm
Carson,
Take John up on his offer, you will gain knowledge from a more experienced Model T'er. likely track down the issue faster. Just my two cents.
Tim Williams
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Jan 17, 2020 10:11 pm
Thanks John for helping that young man out!
All the Best,
Hank
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Jan 17, 2020 10:14 pm
It's great having somebody nearby to help out. I bet John will get you going PDQ.
2nighthawks
First Name: Harold
Last Name: Schwendeman
MTFCA Number: 0
Post by 2nighthawks » Sat Jan 18, 2020 1:19 am
Carson - Might just be something as simple as the starter bendix is jammed. Push the emergency lever all the way forward and rock the car back and forth (....it should move back and forth a few inches) and if it's the bendix jammed,....that should break it loose. Hope this helps,.....harold
2nighthawks
First Name: Harold
MTFCA Number: 0
Post by 2nighthawks » Sat Jan 18, 2020 1:23 am
......oops,.....in reading more carefully, I see that John Warren already suggested this,....sorry John,....harold
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sat Jan 18, 2020 1:34 am
I type similar and I hit the Post button and all is gone. Poof! Darn it. Let's try this No Information Post...
Carson, keep us up to date. :)
Carson, the starter had me right away and was hoping something so simple.... :)
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 2:03 am
Thank you all so much! I will try it all and see if anything does the trick. I really appreciate the help!
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sat Jan 18, 2020 2:11 am
Welcome Carson! Good on you John! I hope its a simple fix and your off and running. I was your age when I bought my 1st car and practiced in the back yard. It was not a T but I learned alot such as you will. Carson can you post a photo of your T?
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 3:01 am
I can absolutely post a picture, but it will need to be in the morning. It is to dark outside now.
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Sat Jan 18, 2020 8:26 am
Interesting. Did the engine move at all with the "start"? If with the rear wheel off the ground and the crank does not turn there is a posibility that the bendix is stuck or worst, something is jambed in the fly wheel. I had a magnet get loose and get between the fly wheel and the pan.
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 9:03 am
No, the engine did not budge with the starter. I stepped on the button and did not hear anything happening other than the coils buzzing. I will try jacking up the rear wheel
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Sat Jan 18, 2020 9:22 am
If it will roll in neutral, jacking up the rear wheel won't make any difference. As others have stated it probably is a jammed bendix. Have John give you a hand.
1926 Tudor
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 9:37 am
OMG. I looked on an old forum from 2015 and one guy said to loosen the 4 bolts on the starter and then rock back and forth. Guess what?!?! It worked! Now I will put it back together and hope it stays fixed! Oh, and you wanted a picture, but I don't know how. Could you tell me?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Jan 18, 2020 10:18 am
Screen Shot 2020-01-18 at 8.51.11 AM.png (10.87 KiB) Viewed 2849 times
Click Attachments.
Screen Shot 2020-01-18 at 8.51.35 AM.png (6.3 KiB) Viewed 2849 times
Click Add files.
Select the photo on your computer that you want to post and click Open.
When the button appears click Place inline.
The title of the image will appear in the composition box. You can type your message above it or below it.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Jan 18, 2020 10:19 am
Click Preview and you should see your image.
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 10:22 am
this is my t!
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 18, 2020 10:25 am
Sorry a bad photo. Here's another.
Mike Royster
First Name: Michael
Last Name: Royster
Post by Mike Royster » Sat Jan 18, 2020 10:41 am
Nice car, welcome to the T world.
Post by Scott_Conger » Sat Jan 18, 2020 10:48 am
Excellent!
Welcome!
Full Flow Float Valves - deliver fuel like Henry intended!
First Name: John T
Last Name: Tannehill III
Post by JTT3 » Sat Jan 18, 2020 11:01 am
Carson I can’t explain in words how wonderful it is to see your post. Many of us ole timers worry about our hobby and the love affair that we have with our model Ts. We need more young folks to have that same enthusiasm that you have to keep it going. I’m also impressed that you took it on yourself to problem solve. The knowledge you can find on the net about model Ts is something many of us lacked early on based on our age and the technology we had when we were young. In a small way it also keeps the memory of T modelers that have passed alive and their knowledge echos through eternity for us to reference. Even at my age I’ve searched the net to solve a problem and see post from older friends long gone that provided the solve. Best of luck, bunch of great gals & guys in the hobby and as you have seen ready to come to your aid. Keep it going.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Sat Jan 18, 2020 11:07 am
Welcome to the forum Carson. Glad you didn't do like me and wait until you were 69 to start working on Model T's. Similar to you I learned to drive by driving my dad's 1955 Ford around our horse pasture. Running over the occasional bush kept the underside clean but is not recommended...
I have a few comments:
1.) You should take John up on his offer to look at your car (thanks John!) - you'd learn something and John could fill you in on the resources available to a Model T-er in your area. Without the help of others my Model T would still be sitting in the barn.
2.) I learned something from this thread - didn't know the Bendix could lock up and how to unlock it.... see what I mean :-)
3.) Be careful loosening the starter. There is a procedure that must be followed to remove it - doing so without removing the bendix first can cause serious damage to other parts that may require engine disassembly.
4.) Do not feel reluctant to ask questions or answer those of others because of your age. On this forum, age doesn't matter. As far as the rest of us are concerned you're just one of the guys.... Again, let me say Welcome and Nice Car!
Tim
1952 Willys M38a1 Jeep
Last Name: House
Post by George House » Sat Jan 18, 2020 12:16 pm
Really nice touring Carson.Welcome to our little group. I was 4 years older than you when I received my first - a ‘23 touring - Model T. Increase your knowledge and enthusiasm for it and the payback - a super chick magnet in high school - will be well worth the effort. And I’d like to echo the philosophy John Tannehill offered.
I’d Rather Suffer Much In Good Company Than To Live Comfortably With Delicate Men..
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sat Jan 18, 2020 3:32 pm
Wow,first T at 12! There is hope for this hobby after all!
Any time you can get a chance to learn from the "old Timers" take it.Their "our" knowledge is usually learned the hard way and easy shared.
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Sat Jan 18, 2020 4:52 pm
Glad that worked for you. However a word of caution. A starter cannot be removed without first removing the Bendix. When the starter spins, the Bendix is driven toward the flywheel from the back. If the Bendix isn't removed first damage to the coil ring will result. So if you have to do this again, be careful not to let the start move very far toward the front of the car. If it continues to do this, remove the Bendix and starter. Check for a straight starter shaft and you may need to replace some parts of the Bendix. I hope you contact John Warren and take all the help and advice you can get.
1926 Tudor
Benp
First Name: Benjamin
Last Name: Perfitt
Post by Benp » Sat Jan 18, 2020 5:41 pm
This is the greatest thread I’ve ever read.
I was 12 when I got my first car. Got a State waiver to get my 1st summer job - neighbor man came over one day and said, “I hear you’re a working man now. (He knew I wanted a model T) I know an old car you might like to see...” He had already asked my Dad’s permission to give it to me, but he asked $500 for it - exactly what I made that summer. He wanted me to have the experience of having worked towards something.
Kept it for 30 years.
Thank you Art - wherever you are.
1952 Studebaker Commander - ugliest car ever built, but sure was a lot of fun. Drove it around that cornfield for YEARS before I had a license.
Still working on getting my 1st Model T....
Mopar_man
Last Name: Govoni
MTFCA Number: 32331
Post by Mopar_man » Sat Jan 18, 2020 6:00 pm
Carson,
Please keep playing around with mechanical things. You have no idea how much you will learn about how to figure out things on your own. You will give yourself confidence to work on anything. I get my daughter in the garage anytime I can. Keep posting about your car and what you are working on.
John Warren
Last Name: Warren
Post by John Warren » Sat Jan 18, 2020 6:32 pm
Carson and his family did meet us for breakfast and guess what......
We were all excited to see his new T. It sounds like the previous owner wanted for Carson to be the new owner. Very nice original car and Carson wants to keep it that way. He does have a few things he needs. AC brakes, he has a small drum ruckstell. I advise him to pick a gear and not shift that for now. He is also in need of two decent used firestone tires. 30X3-1/2. His generator cutout is also sticking. I’m sure he would appreciate any help. It is a great seeing how excited he is about his new car😁
John Warren
Last Name: Warren
Post by John Warren » Sat Jan 18, 2020 6:36 pm
Thanks Steve , looks like he got it😁👏
RalphS
First Name: Ralph
Last Name: Sullender
MTFCA Number: 50327
Post by RalphS » Sat Jan 18, 2020 7:08 pm
Great looking car and your bad photo is better than most of my good ones. Drive as often as you can in circles or a pasture that is how I learned to drive in a 48 pickup. The Model T is much more fun.
Around and around we go and where we stop we check the gas oil water and tires.
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Sat Jan 18, 2020 7:42 pm
This is such a wonderful thread! Congratulations Carson! Very happy for you!
There's not a lot on the internet that makes me happy anymore, but this thread most definitely does!!!
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sat Jan 25, 2020 7:36 pm
Wow! I really appreciate all the help guys! Maybe out model Ts will cross someday! I am so happy I have all this support!
Thank you again!!!
First Name: John T
Post by JTT3 » Sat Jan 25, 2020 11:29 pm
Carson keep up the enthusiasm, the T model changed the world and it certainly did for my corner of it. Best to you.
HalSched
First Name: Hal
Last Name: Schedler
MTFCA Number: 16688
MTFCI Number: 19356
Post by HalSched » Sun Jan 26, 2020 1:17 am
Carson, I got my Model T when I was 12 and I still have it. That was in 1945 and I lived in Wisconsin. I brought it to Sacramento and my boys (teenagers then) and I restored it. Have fun!!!!
IMG_6446 copy 2.JPG (81.76 KiB) Viewed 2112 times
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun Jan 26, 2020 7:10 am
This is an awesome thread. Welcome to the world of T’s Carson.
1924 Touring
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Sun Jan 26, 2020 10:06 am
I am so excited to be a part of this all!
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 26, 2020 11:40 am
Getting a Model T at a young age is a blessing, and getting it in Clark County is even better. There are some great places to explore nearby, and some swell Model T roads. It may seem that the age when it will be legal for you to drive is a long way off, but it will be here before you know it. There are three things I would recommend in the meantime.
1 The most obvious thing is to get the car ready. Your touring may need a few things fixed, or a lot. Fortunately there's a lot of information and help available. Here's a check list. Many of the things listed here may apply to your 1924 touring: http://dauntlessgeezer.com/DG93.html.
2 Practice driving on private property. By the time you go for your driving test for a license you can do the test in a Model T if you want.
3 Get some running board cans. In future years they will save you an inconvenient long walk more than once.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Sun Jan 26, 2020 1:20 pm
Carson - living in the desert you know the importance of water.... I don't know the condition of your radiator and cooling system and whether you plan to run plain water or antifreeze but be aware that it is not unusual for a T with an original type radiator to boil over. The cooling system is not pressurized so boil-overs are just something people got used to back in the day. Steve's advice of carrying extra fluids is good, especially when it comes to coolant. Don't forget a glove or rag for the hot radiator cap :D Having your radiator cleaned by a competent radiator shop is a good idea and might help. Me, I installed a new Bergs flat tube radiator which has almost three times the cooling area of the original round tube types. Something else people did "in the day" was install water pumps. Unfortunately, most of the original designs tend to leak and are seen as unwanted complexity. There is a modern design with sealed bearings available from Texas T Parts if you want to go that route.
As you will soon learn if you haven't already, Model T's are a work in progress. There is always something. Don't be discouraged....just think of the education you're getting!
Next thing we need to figure out is how to get you to Detroit for the Old Car Festival at Greenfield Village some September..... Mecca for old car guys :)
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Thu Feb 20, 2020 11:50 pm
Yes thanks for all the advice! I really want to go to the festival in Detroit. I think it would be so much fun! The only problem Is the distance. I'm sure we will figure it out. Boy I can't wait to be able to drive on the roads!
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Feb 21, 2020 1:00 am
The Old Car Festival is a swell couple of days, but as you say it's a long way from L.V. Even if you flew you'd have to miss a day or two of school. Greenfield Village is historically educational though, with Edison's lab and shops and other neat pieces of history. I aim to keep going in my 1915 as long as they'll let me back in, and you can sure ride it around the village if you want, and drive it when you're legal. :)
https://www.youtube.com/watch?v=RnuJlHbK6Zc&t=128s
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Fri Feb 21, 2020 6:27 am
I would bet you would have more rides in model T's than you have time for at OCF.
Michael Davis
First Name: Michael
Last Name: Davis
Post by Michael Davis » Fri Feb 21, 2020 9:39 am
What a Great bunch of articles to read in this post.
Nice touring Carson.
Mike Davis
Aarongriffey
First Name: Aaron
Last Name: Griffey
Post by Aarongriffey » Sat Feb 22, 2020 12:20 am
Damn, Benp that is a good looking Studebaker. They sure we're beautiful cars.
The first thing I did to my first model T was try to remove the starter without first removing the Bendix drive. I ruined the fields and ran a VW distributor all the years I owned that car.
I think our young new forum member should remove the Bedix and leave the starter on. Hit the starter button and as it spins look to see if the shaft wobbles.
If the shaft is straight just put a new Bendix on.
Let's hope the ring gear teeth are good.
Roverdriver
First Name: Dane
Last Name: Hawley
Post by Roverdriver » Sat Feb 22, 2020 1:05 am
Hello Carson, I sent you a 'P.M.'- a Private Message. Click that wording at the top of the main page to read it, and if you would like, then reply.
Dane.
Mr man
First Name: Carson
Last Name: Combs
Post by Mr man » Mon Feb 24, 2020 9:53 am
Ok. I got the private message! That would be awesome! Thank you.
And to Steve Jeff, I accept your offer!
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Mon Feb 24, 2020 1:46 pm
Carson, if you are doing OK at school, then a trip to OCF for a weekend will teach you more than a week at school sitting behind a desk. I was lucky enough to have parents that understood that. On hand experiences are the best education you can get. Just watch out for that guy named Dallas - he would probably make you take a test. :)
