Sure Mic Crank?
Posted: Sun Jan 26, 2020 9:47 pm
by ThreePedalTapDancer
I have a Sure Mic counterweighted crank I recently retrieved from a estate. Is it a boat anchor or does it have value?
Re: Sure Mic Crank?
Posted: Sun Jan 26, 2020 9:57 pm
by Dan McEachern
1) measure the journals 2) have it magnafluxed.
Re: Sure Mic Crank?
Posted: Sun Jan 26, 2020 10:04 pm
-13, -20, -25,-30.
Re: Sure Mic Crank?
Posted: Sun Jan 26, 2020 11:19 pm
by NoelChico
I have one in my 26 and it is smooth. Some have had problems with them but I suspect that if they have lasted 100 years they'll last a few more.
Re: Sure Mic Crank?
Posted: Mon Jan 27, 2020 12:17 am
by Kerry
They do crack, so as Dan posted, the first thing is a crack test, if you are not willing to invest or take a chance on doing your money, then the buyer would take that chance, so sort of makes it worthless at a buyers prospective.
Re: Sure Mic Crank?
Posted: Mon Jan 27, 2020 2:28 am
by Les Schubert
If I interpret your undersize measurements correctly, one of the journals is.030” worn.
I make it a policy to not use a crank that is smaller than.020” undersize.
My “rationale” is that the crank has too many “cycles” of use and is beyond its useful fatigue life.
Just my policy.
Additionally I will only use a Sure Mike in a comparably stock configuration engine, not in one significantly “souped up”
Re: Sure Mic Crank?
Posted: Mon Jan 27, 2020 7:32 am
by Ralph F
I have sure Mic in my 15 touring. My father found this crank in a busted block in the late 50. I just had the motor rebuild 2 years ago by Pats Restoration and it still usable. I don't drive much over 35 mph.
Fitz
