26 Tudor For Sale
Topic author - Posts: 89
- First Name: Kent
- Last Name: Palazzo
26 Tudor For Sale
Selling my 26 Tudor. The driveline is earlier, Nov.1919 by the engine number. Older restoration, not a show pony, runs and drives good.
Engine has aluminum pistons/transmission has Kevlar bands.
$9000 or best reasonable offer.
List of items I replaced over winter.
Rear axle/driveshaft rebuilt, housings were only things not replaced.
New axles
Driveshaft
Modern spool assembly
New U-joint
AC Brakes/equalizer cables
Wire wheels
New tires, tubes, flaps
New Brassworks Radiator
New water pump
Fan hub/sealed bearings
6volt alternator/voltage regulator
6volt starter solenoid
New starter bendix
Transmission screen filter
Foot throttle
Fuel shutoff/Sediment trap
New ignition switch/ammeter
Outside mirrors
New axles
Driveshaft
New U-joint
Wire wheels
New water pump
New starter bendix
Foot throttle
Outside mirrors
- First Name: Kent
Re: 26 Tudor For Sale
To the top
- First Name: Austin
- Last Name: Farmer
Sorry to hear you are selling your T!
Good luck with your sale!
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
check your email, thanks
- Last Name: Reep
Is the diff. a 26-7 or earlier
Appears to be a small drum w/wires & outside brakes.
