Very nice 1926 Coupe
Topic author - Posts: 441
- First Name: Ed
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1909 replica Transcontinental race car, 1915 2 man race car, 1918 American bodied speedster
- MTFCA Number: 19
- Board Member Since: 2009
Helping an old friend sell her diseased husbands 1926 Ford Coupe. Very nice older restoration needing nothing. Ready for the next touring season. Ruckstell rear end, Rocky Mountain brakes, varnished wood wheels, Motometer and dogbone cap, extra chrome trim on both interior and exterior. Take a look at the pictures. $9,500.00. More pictures on request.
Ed aka #4
Ed aka #4
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
- MTFCA Number: 373
- MTFCI Number: 184
Re: Very nice 1926 Coupe
Ed is that one of Bob's cars? I may be down in May.
Jim
Jim
- First Name: Robert
- Last Name: Jablonski
- MTFCA Number: 407
Ed: Please send more pictures to me, is seat moved for more legroom ?? Thanks in advance.
Bob Jablonski
Bob Jablonski
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Hi Bob, sorry for the delay in responding I just saw your note. Send anything else to my email address karened4@att.net. I pick up my emails 3 or for times a day. I'm not sure I know how to send any pictures using this reply area so if you get no pictures and are still interested send me an email. Anything specific that you want to see? Thanks
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
I would buy from Ed Archer if I was
an Eskimo living in Alaska ...
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- First Name: Doug
- Last Name: Murphy
Jim,
What would it cost to ship this car to Fishkill, NY? I am curious as to the added cost because all the nicest T's seems to be on the west coast.
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Need to add a little revision to this classified. The starter isn't operating properly. Turning over the engine so slowly that it won't start the engine. It starts immediately with the hand crank on both magneto and battery and runs extremely well.
Ed aka #4
Ed aka #4
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Ed. That sounds like a ground problem, which is odd for a 26 with the steel straps from engine to the frame mount bolt. You could add a temp ground wire from engine to frame to see if it helps with the cranking speed.
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Thanks for the tip Kevin I'll try it. I'm brain dead when it comes to electricity.
Ed aka #4
Ed aka #4
- First Name: Kevin
Ed, I forgot to mention that it is the four starter to hogshead screws/bolts that ground the starter to the engine. You could remove the one you can get to and clean it, replace screw adding a star washer for better ground.
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
Preaching to the choir. But make sure both of the starter switch posts and cable lugs are clean. shiny and TIGHT along with battery posts. positive and negative. ground lugs and clamps. starter post and lug as well. at 6 volts it doesn't take much corrosion to really reduce starting power and speed. a loose connection will do it every time and the faulty connection after a little starting will be warm or Too HOT To Touch. some times a previous owner has changed out the battery cable out and used a smaller gauge cable made for 12 volts. but the smaller cable robs a good portion of power needed for a 6 volt starter to work properly.
my 2 cents worth maybe less
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Thanks Jim, y'now I never even looked at the size of the cable, but I think it's big. I'll do a little checking.
Ed aka #4
Ed aka #4
- First Name: Jim
- Last Name: Melicharek
Asking if you would send me the additional pictures. Appreciate it, Jim
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Here's the pictures as requested, Jim. I'm at my limit here so I'll add a couple of more in a separate post.
Ed aka #4
Ed aka #4
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
Here's a few more. In the fourth one, if you have a way to bring it in closer you can see one of the areas that I mentioned where the paint is scraped off. About 3" tall, just to the left of the rear window and the vertical body seam. Also a small one on the door window frame, hard to see in the picture.
Ed aka #4
Ed aka #4
- First Name: Charlie
- Last Name: Debo
- * REQUIRED* Type and Year of Model Ts owned: 1914 runabout, 1923 Touring, 1924 TT, 1925 Doctors Coupe
- MTFCA Number: 51229
Greeting's, I am interested buying your model t coupe. My name is Charles Debo is this car still for sale, if so, please call me, I live in Central Oregon; 541-504-9493 or 541-771-6277 I look forward to hear from you.
- First Name: Ed
- Last Name: Archer
- MTFCA Number: 19
The coupe is sold. Thanks MTFCA
