Very nice 1926 Coupe
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Board Member Since: 2009
Post by YellowTRacer » Sun Mar 07, 2021 2:32 am
Helping an old friend sell her diseased husbands 1926 Ford Coupe. Very nice older restoration needing nothing. Ready for the next touring season. Ruckstell rear end, Rocky Mountain brakes, varnished wood wheels, Motometer and dogbone cap, extra chrome trim on both interior and exterior. Take a look at the pictures. $9,500.00. More pictures on request.
Ed aka #4
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
MTFCA Number: 373
MTFCI Number: 184
Re: Very nice 1926 Coupe
Post by JvanMaanen » Sun Mar 07, 2021 12:32 pm
Ed is that one of Bob's cars? I may be down in May.
Jim
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Post by Moxie26 » Fri Mar 12, 2021 2:43 pm
Ed: Please send more pictures to me, is seat moved for more legroom ?? Thanks in advance.
Bob Jablonski
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Mon Mar 15, 2021 12:29 pm
Hi Bob, sorry for the delay in responding I just saw your note. Send anything else to my email address karened4@att.net. I pick up my emails 3 or for times a day. I'm not sure I know how to send any pictures using this reply area so if you get no pictures and are still interested send me an email. Anything specific that you want to see? Thanks
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
Post by FreighTer Jim » Mon Mar 15, 2021 8:58 pm
I would buy 🧊 from Ed Archer if I was
an Eskimo living in Alaska ... 🥶
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Doug 845
First Name: Doug
Last Name: Murphy
Post by Doug 845 » Tue Mar 16, 2021 3:39 pm
Jim,
What would it cost to ship this car to Fishkill, NY? I am curious as to the added cost because all the nicest T's seems to be on the west coast.
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Wed Mar 24, 2021 3:14 pm
Need to add a little revision to this classified. The starter isn't operating properly. Turning over the engine so slowly that it won't start the engine. It starts immediately with the hand crank on both magneto and battery and runs extremely well.
Ed aka #4
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
MTFCA Number: 11598
Post by kmatt2 » Wed Mar 24, 2021 6:37 pm
Ed. That sounds like a ground problem, which is odd for a 26 with the steel straps from engine to the frame mount bolt. You could add a temp ground wire from engine to frame to see if it helps with the cranking speed.
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Wed Mar 24, 2021 6:57 pm
Thanks for the tip Kevin I'll try it. I'm brain dead when it comes to electricity.
Ed aka #4
kmatt2
First Name: Kevin
MTFCA Number: 11598
Post by kmatt2 » Wed Mar 24, 2021 7:49 pm
Ed, I forgot to mention that it is the four starter to hogshead screws/bolts that ground the starter to the engine. You could remove the one you can get to and clean it, replace screw adding a star washer for better ground.
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
Post by Novice » Thu Mar 25, 2021 2:43 pm
Preaching to the choir. But make sure both of the starter switch posts and cable lugs are clean. shiny and TIGHT along with battery posts. positive and negative. ground lugs and clamps. starter post and lug as well. at 6 volts it doesn't take much corrosion to really reduce starting power and speed. a loose connection will do it every time and the faulty connection after a little starting will be warm or Too HOT To Touch. some times a previous owner has changed out the battery cable out and used a smaller gauge cable made for 12 volts. but the smaller cable robs a good portion of power needed for a 6 volt starter to work properly.
my 2 cents worth maybe less
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Thu Mar 25, 2021 4:59 pm
Thanks Jim, y'now I never even looked at the size of the cable, but I think it's big. I'll do a little checking.
Ed aka #4
RedDog
First Name: Jim
Last Name: Melicharek
Post by RedDog » Sun Mar 28, 2021 2:25 pm
Asking if you would send me the additional pictures. Appreciate it, Jim
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Sun Mar 28, 2021 5:45 pm
Here's the pictures as requested, Jim. I'm at my limit here so I'll add a couple of more in a separate post.
Ed aka #4
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Sun Mar 28, 2021 6:08 pm
Here's a few more. In the fourth one, if you have a way to bring it in closer you can see one of the areas that I mentioned where the paint is scraped off. About 3" tall, just to the left of the rear window and the vertical body seam. Also a small one on the door window frame, hard to see in the picture.
Ed aka #4
Chuck Debo
First Name: Charlie
Last Name: Debo
* REQUIRED* Type and Year of Model Ts owned: 1914 runabout, 1923 Touring, 1924 TT, 1925 Doctors Coupe
MTFCA Number: 51229
Post by Chuck Debo » Sun Apr 04, 2021 11:32 pm
Greeting's, I am interested buying your model t coupe. My name is Charles Debo is this car still for sale, if so, please call me, I live in Central Oregon; 541-504-9493 or 541-771-6277 I look forward to hear from you.
YellowTRacer
First Name: Ed
Last Name: Archer
MTFCA Number: 19
Post by YellowTRacer » Sat Apr 17, 2021 2:38 am
The coupe is sold. Thanks MTFCA
