***SOLD***1926 Speedster ***SOLD***
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Post by Jeepbone1 » Tue May 11, 2021 9:48 am
***SOLD***
I’ll have my fenderless 26 speedster for sale at the Luray swap meet. 26 engine w/ matching VA title in my name. Home built body by us. Big toolbox on the back nice round gas tank between the seat and box. Motor was gone through about a year and a half ago. Cylinders bored with new egge 0.040 over aluminum pistons, SS valves adjustable tappets. New exhaust manifold with new tail pipe and new stamped muffler(tack welded) New 4th main from gene French, RV Anderson mag ring with recharged magnets, jack rabbitt clutch and Texas t 12v alternator. 1930something Chevy wire wheels with new 475-500-19 universal tires, tubes and flaps. Rebuilt small drum axle(wheels don’t fit over a large drum) . New thrust washers, thrust pins, bearing sleeves, neoprene inner and outer seals, accessory relined parking brake shoes. New rear shackle bushings. New bushings in front spring shackles and spindle arms. New water pump. Radiator doesn’t leak and cools well with the pump. Starter works as it should and has a new bendix spring and hardware on a good original bendix. Wired for 12v lights and turn signals and brake lights. Replaced the brake quadrant, ratchet pawl and springs. Parking brakes adjusted and functioning properly. Good set of Kevlar bands. Runs and drives as it should on battery and mag. Coils rebuilt and setup on ECCT. Fresh wiring and new starter button. Pictures will be available as soon as I dig my crap out from around it. Price will be $4800 or best offer. Feel free to call/ text or email anytime at bkirtner(AT)gmail.com and 54zero761two303
The car is currently in Salem va.
I’ll be loading the car up and taking it to the Luray swap meet.
Brad
***SOLD***
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
MTFCA Number: 5880
MTFCI Number: 5880
Board Member Since: 2014
Re: FS1926 Speedster
Post by Rjackson » Tue May 11, 2021 11:44 am
Where are you located and do you have pictures
Loftbed
First Name: Rod
Last Name: Letcher
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
MTFCA Number: 32097
Post by Loftbed » Tue May 11, 2021 11:47 am
pictures???
:D
1965 Shelby Cobra (Factory Five repo)
1957 Ford Thunderbird
1941 Ford PU
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Tue May 11, 2021 1:15 pm
Pictures coming later today. Add updated with location.
Brad
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Tue May 11, 2021 5:10 pm
More pictures.
Brad
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Tue May 11, 2021 5:11 pm
Last set of pictures.
Brad
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Wed May 12, 2021 6:42 pm
Starting, running and driving videos available for those interested.
Brad
