FS 1910 Model T Touring $24,500
Topic author - Posts: 13
- First Name: joe
- Last Name: caraway
- * REQUIRED* Type and Year of Model Ts owned: 1910 touring 26tt
- MTFCA Number: 24128
January 7, 1910 Touring #14547 with original open valve motor. Original Beaudette body and doors. Original John Brown lights except tail light. All original fenders, hood and panels. New top, new leather. Original Rands windshield. Stewart 24 speedometer. Original early running boards. Rocky Mountain brakes. Electric start. This car runs and drives! Call Joe for details. (480)998-6617 $24,500
SOLD
SOLD
- First Name: joe
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 LHD USA Touring 1916 RHD Canadian Touring 1916 Pickup
Re: FS 1910 Model T Touring
I looked at the add originally just out of curiosity. It is a beautiful 1910. Then I realised after a second look the engine number is only 18 different from my Dads old 1910 no#14529 also January 1910. However, both numbers had very different lives. 14529 went over the river to Canada, was fitted with a Canadian timber body and shipped to Australia. I have a picture of the factory job card somewhere. I will try and find it to post here. All the best with the sale. It should sell easily.
- First Name: Doug
- Last Name: Murphy
Beautiful car. No mention of engine work. Why no spark plug wires? What is the engine number?
- First Name: joe
- First Name: joe
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
The engine block does not have the casting ridge on the valve side that all 1909 and 1910 engine blocks have.
- Last Name: Gould
Not all of them did. I had two original open valve blocks that did not.
- First Name: Ed
- Last Name: Martin
Some have a distinct casting line, others it is more faint. The reproduction blocks are uniform with no casting line.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
An interesting situation. My note is that on the several early Model T Fords I have owned and on those I viewed over the 70 years, the stamped numbers were all nice and straight and even in a line. The numbers stamped on this engine are not, they appears tohave done my someone other than one at a Ford factory.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
The number, of course do not have to be perfect, but those I have seen are much nicer. Also the embossment seems rather deep. much deeper that those I have seen. Take a look at the 1910 Kim Dobbins sold and at the close up of the engine number (the second photo showing the number.) note how shallow the embossment is.
- First Name: joe
- First Name: joe
Also mysterious casting bulge on driver’s side block. Seen on early open valve engines.
- First Name: joe
No casting date on the block as early blocks don’t usually have.
- Last Name: Landy
Joe, the extra " bulge" you refer to above was also a feature of engine no. 14529 indicating they were part of limited run of blocks late 1909 to early 1910.
- First Name: Wilber
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1910 Model T Touring
- MTFCI Number: 22121
My February, 1910 touring, no. 15841 also has that threaded boss: I made use of it with an outside oil line!
- First Name: David
- Last Name: Treacher
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster
Re: FS 1910 Model T Touring $28,500
Hi Joe,
Is your 1910 Touring still available please ?
I sent you a private message also.
Cheers, David.
Cheers, David.
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1912 Warren Speedster
- MTFCA Number: 50392
Yesterday. I flew to Scottsdale, AZ. to look at this 1910 Touring. It's now a running car. I drove it a few blocks and shifted its 2 speed Jumbo Planatar transmission. It has some body blemishes but I liked it and think it could be a nice car for the right buyer. I enjoyed meeting the seller Joe and talking 1910 Model Ts.
Here are some pictures that I took.
Here are some more pictures that I took.
- First Name: Ed
- Last Name: Martin
I’m confused, the first set of pictures show the correct one piece spindle front axle, but the last close up picture of the axle is a different modified later front axle with material added to make it look like an early one? The wheels are red too? Probably posted the wrong pic.
That is a nice looking car. If it goes as well as it looks, it would make a nice touring car. If you are looking for a "correct" 1910 model, there is lots to correct, and some of it is quite spendy to acquire.
Allan from down under
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Be carefull driving this car, the pictures show the 1919 -1927 type under axle type front spring perches mounted on the wrong sides. The bosses go to the back side of the axle when properly mounted to give correct front axle steering geometry.
Explanation:ThreePedalTapDancer wrote: ↑Sat Sep 04, 2021 5:52 pmI’m confused, the first set of pictures show the correct one piece spindle front axle, but the last close up picture of the axle is a different modified later front axle with material added to make it look like an early one? The wheels are red too? Probably posted the wrong pic.
The "modified" axle (pictured attached to red wheels) will be swaped to this 1910 Touring prior to it changing hands.
The 1910 original axle (pictured earlier) will be removed and kept by the owner for use on his other T.
- First Name: Kevin
- Last Name: Mocyk
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Re: FS 1910 Model T Touring $24,500
So it’s getting stripped of it’s correct 1910 front axle? What a shame!
- First Name: Mike
- Last Name: Coats
- MTFCA Number: 51925
Is this car still for sale
