For sale Unique 1927 RAJO engine T Roadster
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Sat Jun 19, 2021 1:05 am
A friend has put up his 1927 Roadster for sale. The car is a good amature restoration, no rust and a good paint job. The unique item is the motor. As you can see on the details below it really is special. It is believed to be the last motor built by Fred Hoss and was built to unusually high standards. After installation is the car, there were some issues with the four bolts connecting the crank and the transmission. These were resolve by an very experienced machinist, using all grade 8 bolts.
The car will see off 99% of all Ts on the road but is traceable enough to comfortable run behind my 24 Coupe on a tour. Quite a car
1927 FORD MODEL T ROADSTER
1927 Motor:
• Motor number matches current registration, and is the last motor built by Fred Hoss • Counter-balanced Model A Crank
• Model A 330 grind cam
• RAJO 8 valve head has self-oiling at lifters
• Insert bearings
• E.J. custom pistons
• Billet custom made rods
• Pressurized oil system – 50# pressure
• New 4 core radiator
• Electric fan – automatic turn-on and off
• High output 12 volt starter
• New heavy duty battery
• 12 volt alternator with dash light
• 2 barrel down draft carburetor
• Aluminum high capacity oil pan
• Motor has 1,280 mile since installed, 4 tours climbing to 10,000 feet
Rebuilt Ruckstell rear-end
• Safety floating rear bearing hubs
• Pre-sealed bearing center hub
• Ruckstell shifter moved to left side for convenience
Other Features:
• New Kevlar bands in transmission
• Hydraulic disk brakes
• 4 Brand new tires
• Wire Wheels (will paint any color wanted)
• Motometer with working thermostat
• 12 volt stop lights
• Front and rear turn signals
• Rear view and side mirrors
• Rear spare tire and carrier
• Top in fair shape and is removable
• Seat and door panels in good shape
• Shackles and bearings in good shape
• Windshield wiper
• Accessory plug ins (one in trunk, one up front)
On Dash:
• GPS speedometer with other features (Clock, elevation, trip meter, odometer etc.) • Inside release for cowl gas cover
• Two map lights
• Oil pressure gauge
• Battery clock
• Horn
The car is available in Southern California for viewing at any mutually convenient time. More pictures to interested buyers are available on request. Delivery is an option in either an open or closed trailer. Asking price is $20,000.
Side view of 27 roadster
Rajo motor
Rajo motor
Contact by email is preferred to tonybowkerATaol.com. You know what to do with the AT. 😊
Tony Bowker
La Mesa, California
