1911 touring
Michael Paul
First Name: Michael
Last Name: Paul
* REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
MTFCA Number: 31791
1911 touring
Post by Michael Paul » Sat Jul 31, 2021 3:59 pm
Original seats, fenders, doors, running boards, hood, steering column, frame, axels, hogshead, pedals,lights, hub caps, 2 piece driveshaft, springs, Mae west shackles, repo side light brackets, tail light brackets, firewall, radiator has made in USA but has correct for 1911 new tank front included. Enough parts to make a couple rand's windshields. Engine is 1912 or 13 that someone altered to look like 1911, has thick valve covers, block is very solid. Pan is 7 rivet but appears to be a 1912 or early 13 pan. Transmission is later. Have top sockets somewhere, I'll throw them in if I can find them. $8750. Picked up in Northern California.
707 four eight six 8420
Mike
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: 1911 touring
Post by Michael Paul » Sat Jul 31, 2021 11:01 pm
7074868420
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: 1911 touring
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
1911 touring
Post by FreighTer Jim » Sun Aug 01, 2021 10:10 am
That - is a great deal Michael 👍
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: 1911 touring
Post by Michael Paul » Sun Aug 01, 2021 4:30 pm
Also found one correct splash apron and cast style brake lever.
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: 1911 touring
Post by Michael Paul » Fri Aug 06, 2021 2:24 pm
Part it out?
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: 1911 touring
Post by Michael Paul » Fri Aug 06, 2021 4:45 pm
Now parting out. Probably should move to parts section.
Rear 12 rivet axel with two piece driveshaft and cast radius rods $2500. Frame with running board brackets and cast rear body mounts, $800. Front axel with wishbone $400. Engine block $1500. 7 rivet pan $500. Radiator $400. Hood $200, firewall $100. Sidelamp brackets $75. Hood former $100, headlights $400
starting crank with aluminum handle $75 sidelights $300 taillight, $200 steering column $500. Hogs head with pedals $200 all four fenders $800. One splash apron $100. Running boards $150. 4 hub caps $70 set of wheels and hubs $400 body with doors $2500.
Wayne_Lemin
Last Name: Lemin
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster
Board Member Since: 2012
Re: 1911 touring
Post by Wayne_Lemin » Sat Aug 07, 2021 9:29 pm
Hi Michael, is your rear axle assembly still available
Wayne_Lemin
Last Name: Lemin
Re: 1911 touring
Post by Wayne_Lemin » Sun Aug 08, 2021 4:57 am
Hi Michael, I've sent you an email regarding rear axle assembly
