1911 touring
Topic author - Posts: 365
- First Name: Michael
- Last Name: Paul
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
- MTFCA Number: 31791
1911 touring
Original seats, fenders, doors, running boards, hood, steering column, frame, axels, hogshead, pedals,lights, hub caps, 2 piece driveshaft, springs, Mae west shackles, repo side light brackets, tail light brackets, firewall, radiator has made in USA but has correct for 1911 new tank front included. Enough parts to make a couple rand's windshields. Engine is 1912 or 13 that someone altered to look like 1911, has thick valve covers, block is very solid. Pan is 7 rivet but appears to be a 1912 or early 13 pan. Transmission is later. Have top sockets somewhere, I'll throw them in if I can find them. $8750. Picked up in Northern California.
707 four eight six 8420
Mike
Mike
- Last Name: Paul
Re: 1911 touring
7074868420
- Last Name: Paul
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
1911 touring
That - is a great deal Michael
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- Last Name: Paul
Re: 1911 touring
Also found one correct splash apron and cast style brake lever.
- Last Name: Paul
Re: 1911 touring
Part it out?
- Last Name: Paul
Re: 1911 touring
Now parting out. Probably should move to parts section.
Rear 12 rivet axel with two piece driveshaft and cast radius rods $2500. Frame with running board brackets and cast rear body mounts, $800. Front axel with wishbone $400. Engine block $1500. 7 rivet pan $500. Radiator $400. Hood $200, firewall $100. Sidelamp brackets $75. Hood former $100, headlights $400
starting crank with aluminum handle $75 sidelights $300 taillight, $200 steering column $500. Hogs head with pedals $200 all four fenders $800. One splash apron $100. Running boards $150. 4 hub caps $70 set of wheels and hubs $400 body with doors $2500.
- Last Name: Lemin
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster
- Board Member Since: 2012
Re: 1911 touring
Hi Michael, is your rear axle assembly still available
- Last Name: Lemin
Re: 1911 touring
Hi Michael, I've sent you an email regarding rear axle assembly
