For Sale: 1913 Touring - $11,500 or b/o
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:26 pm
For sale:
1913 Ford Touring with July 1913 engine (serial # 307134).
The car is registered and insured with a clear NJ title in my name.
The car runs (on battery and mag), drives, and stops well.
Small battery included with car.
Video of the car running and driving from 8/1/21:
https://m.youtube.com/watch?v=mzRZ-Z9W54A
The original rust-free gas tank has been removed, cleaned, and sealed
Holly NH carb (currently on the car) and brass 1913 Holly 2 Screw were both rebuilt by Corey Walker.
Coils checked and coil box rebuilt by R V Anderson. All new ignition and timer wiring.
Light brown show ignition wiring included with the car.
Correct working and restored speedometer, swivel, chain, and housing.
A set of original recall brackets are on their way from California and will be included in the sale.
Excellent set of 5 E and J brass lights.
Carbide tank ready to use ( just needs to be hooked up).
Good 30 X 3 non-skid tires on the front.
Decent 30 X 3.5 tires on rear.
I have a brand new 30 X 3.5 non-demountable rim and a good hub to replace the passenger rear rim ( currently demountable).
The car comes with restored top sockets, new radial cut top bows, new top straps, and a brand new top with roll up rear window from Classtique - all ready to install.
The original bows are also included should the new owner want them. Total spent on bows, sockets, and new top- $1800.
Repro. 1913 Delaware license plate, excellent original oil cap, an extra mint hubcap, some original and repro. literature, and an original Ford script brass tire pump are all included in the sale.
As you can see in the photos, the car will need paint.
I’m happy to provide as many photos as a serious buyer would like. Just email.
Shown by appointment.
Gene
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Re: For Sale: 1913 Touring - $11,500 or b/o
Post by GEmering » Sat Oct 23, 2021 11:29 pm
Additional photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:34 pm
More photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:37 pm
More photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:42 pm
More photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:51 pm
More photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sat Oct 23, 2021 11:54 pm
More photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sun Oct 24, 2021 12:06 am
Last set of photos
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sun Oct 24, 2021 12:55 am
Here’s a few more.
Gene Emering
Newton, New Jersey
norrie_model_t
First Name: norrie
Last Name: mavre
* REQUIRED* Type and Year of Model Ts owned: 1926 Ford Model T Sedan
MTFCA Number: 31587
Post by norrie_model_t » Sun Oct 24, 2021 8:03 am
I have sent you a private message can you put my name down as the first interested?
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sun Oct 24, 2021 8:14 pm
Sale pending
Gene Emering
Newton, New Jersey
TSteve
First Name: Stephen
Last Name: Wirtes
* REQUIRED* Type and Year of Model Ts owned: Presently searching for a driver-quality Touring model.
MTFCA Number: 51835
Post by TSteve » Sun Oct 31, 2021 12:03 pm
Good morning, Gene. I'm a new member and have begun my search for a T. Is your T still available?
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
Post by Novice » Sun Oct 31, 2021 3:36 pm
Steve. Model Ts built prior to 1919 did not have the electric starter option and were hand crank only unless a starter had been added later. Genes 1913 is hand crank only. Look at photo of the rear left side of the engine that's where the starter is located if it has one.
Nothing wrong with hand crank if that's what You want.
Good luck
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sun Oct 31, 2021 5:32 pm
And it sold to Norvi in Scotland!
GEmering
First Name: Gene
Last Name: Emering
MTFCA Number: 49671
Post by GEmering » Sun Oct 31, 2021 6:29 pm
Yes, thanks Tim.
The car is sold.
Thank you MTFCA
Gene
Gene Emering
Newton, New Jersey
