1924 Coupe in SE Michigan
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Wed Apr 27, 2022 2:20 pm
1924 Coupe for Sale. It's an older restoration but in good shape and running good - ready for touring. The car is 6 volt and retains the original Ford coils. Runs on Battery or Magneto. The car is located in Michigan, NE of Detroit. Delivery is available by arrangement. The car could also be delivered to Luray if that would be more convenient.
Asking $9000.
Call Brian 586-864-5110
jayjbehm
First Name: Jay
Last Name: Behm
* REQUIRED* Type and Year of Model Ts owned: 1926
Re: 1924 Coupe in SE Michigan
Post by jayjbehm » Tue Jun 07, 2022 10:29 pm
Hi. What is the overall height? Thank you
jayjbehm
First Name: Jay
Last Name: Behm
Post by jayjbehm » Tue Jun 07, 2022 10:35 pm
Also, does this have the starter button the floor or is it crank start only? Thank you.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Wed Jun 08, 2022 3:27 pm
Unless something is missing, which I highly doubt, this car would have an electric starter.
jayjbehm
First Name: Jay
Last Name: Behm
Post by jayjbehm » Wed Jun 08, 2022 5:24 pm
Thank you. There's much to learn about the Model T as I start looking for one. Do you know the overall height? I have a sub standard garage door height and I need to check that before anything else probably.
Jay
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Jun 08, 2022 7:45 pm
Hi, in my knowledge 24 coupe is six foot four inches, or 76 inches, on 30X3.5 wheels and tires. If 21 inch balloon wheels and tires (an option in 1925) were used, the height could be about an inch lower. If the car has accessory shock absorbers (Hasslers or some others), they can raise the height by an inch or even more. Condition and arch of the spring can also vary it a bit. Hope these info help. I have no link with Tim, but I would say his car is pretty.
Super Mario Bross ;)
1911 Touring
1914 Speedster
jayjbehm
First Name: Jay
Last Name: Behm
Post by jayjbehm » Wed Jun 08, 2022 8:08 pm
That's great information. I finally got to see and ride in a T Tudor at the Homecoming last Sat. They do seem taller than I expected but they are also very impressive. I am hoping one of the 1927s with wire wheels could squeeze through a clear height of 73 5/8" of my garage door. A coupe or sedan is preferred but if not possible I'll probably need to find a roadster with its top lowered. Thank you again!
Jay
