SOLD ---1926 Ford Model TT dump truck.
Posted: Tue Jul 25, 2023 9:03 am
AWARDED the GOLD at the 2023 MTFCI tour in Baraboo, Wi.
SCAT Counter balanced stroker. Z Head, Stipe improved grind camshaft, Ruxstell Hi speed rear end, Twin Hi-Lo auxiliary (under, direct & overdrive) transmission, Heil dump box, "Sure Stop" Hydraulic disc brakes, Stainless steel exhaust pipe & muffler, Adjustable valve lifters (2 wrench style), Two auxiliary oil systems, Stewart speedometer, 6 vdc to 12 vdc transformer for charging phone/GPS, Directional signals, John Regan voltage regulator, Kevlar bands, "Belly Sling" oil pan support, Neville "Fatman" steering wheel, Tool Box, Auxiliary gas cans, Brassworks flat tube radiator, Turbo 400 clutch discs, Handbrake extension, ANCO "Hot spot" intake/exhaust manifold and much more. $16,500 call or text at 920-226-1005 as well as email 26modeltt@att.net
