1915 Touring on Hemmings
Posted: Thu May 02, 2024 11:16 pm
by old_charley
Re: 1915 Touring on Hemmings
Posted: Fri May 03, 2024 11:06 am
by Michael Peternell
That would seem to be a very fair price.
Posted: Fri May 03, 2024 4:22 pm
by Humblej
Wow, if I was closer...and needed another model t...
Posted: Fri May 03, 2024 7:07 pm
by 1925 Touring
Radiator is worth half that alone!
Posted: Fri May 03, 2024 8:45 pm
by BRENT in 10-uh-C
1925 Touring wrote: ↑Fri May 03, 2024 7:07 pm
Is an old radiator like that which is likely on its 'last hurrah' really worth that much?
I applaud the Seller for realizing what this car isn't and pricing it accordingly. As I was looking at that car, do you suspect it is too far deteriorated to even be brought back as a 'survivor'? I'd say the body wood and sills are shot, and maybe the same for the top bows (-and maybe irons too)? I would think the car likely needs the rear axle gone thru to change the thrust washers, and the fuel system replaced due to rust, ...and the wheels respoked, likely rims replaced, and definitely something newer than those Non-Skid tires & tubes. Probably better factor in a new radiator, and some motor work. When you add it all up, it really needs a lot of labor and money spent on it where it can reliably Stop, Start, and Steer.
