F.S. 1915 model T touring - New lower price!
Posted: Mon Aug 19, 2024 12:48 am
I bought this 1915 touring six years ago, since then I had most of the repairs done and new parts installed within the last year or two.
- Had the motor and transmission professionally rebuilt with about two thousand miles on it since,
New aluminum pistons, new valves and seats, 280 cam, new Babbitt, re ground crank, new intake and exhaust manifolds, new ring gear for the starter, rubber seals on the pedal cams, resurfaced head and the block, outside oil line to the front of the motor.
- Five new tires, tubes and flaps installed on demountable rims. Spare tire & bracket in back.
- LED lights all around, driving, directional and brake lights.
- Rebuilt ruckstell rear axle with Rocky Mountain brakes.
- New top upholstery, top and seats.
- New front tapered leaf spring.
- Rebuilt front axle.
- New gas tank and sediment bowl.
- Rebuilt NH carburator
- New brass flat tube radiator three years ago.
- Safety glass in windshield.
- Tool box on running board.
- Aluminum step plates.
- New Day timer.
- Kevlar bands, new.
The body has older paint and bumps and dents that could be taken out if you wish but I thought it gave it an old car flavor that I like. This is definitely a nice driver which got many waves and thumbs up on many tours, more thumbs up than the shiny expensive paint jobs.
It is not a perfect car but a good running solid driver.
A new timing gear was installed with the motor rebuild but it makes a little noise.
Come and take it for a drive in Prescott Arizona, up in the hills. $ 14,950.. or best offer
Frank eight one eight two five four six seven nine seven
Call or text
sarikatime@yahoo.com
- New Day timer.
Call or text
