26 Tudor For Sale "PRICE LOWERED"
Posted: Mon Jul 21, 2025 1:27 pm
by Shrshot
Selling my 26 Tudor. The driveline is earlier, Nov.1919 by the engine number. Older restoration, runs and drives good.
Engine is rebuilt with new babbitt, and aluminum pistons/transmission has been rebuilt with Kevlar bands.
$8000 or best reasonable offer.
List of items I replaced over winter.
Rear axle/driveshaft rebuilt, housings were only things not replaced.
New axles
Driveshaft
Modern spool assembly
New U-joint
AC Brakes/equalizer cables
Wire wheels
New tires, tubes, rim liners
New Brassworks Radiator
New water pump
Fan hub/sealed bearings
6volt alternator/voltage regulator
6volt starter solenoid
New starter bendix
Transmission screen filter
Foot throttle
Fuel shutoff/Sediment trap
New ignition switch/ammeter
Outside mirrors
Re: 26 Tudor For Sale
Posted: Sun Jul 27, 2025 11:43 am
by Shrshot
To the top
Posted: Sun Jul 27, 2025 1:14 pm
by 1925 Touring
Sorry to hear you are selling your T!
Good luck with your sale!
Posted: Sun Jul 27, 2025 2:10 pm
by Wingnut
check your email, thanks
Posted: Sun Jul 27, 2025 2:24 pm
by Wingnut
Is the diff. a 26-7 or earlier
Posted: Sun Jul 27, 2025 4:12 pm
by RajoRacer
Appears to be a small drum w/wires & outside brakes.
Posted: Sun Jul 27, 2025 6:19 pm
by Shrshot
Good eye Steve. Yes it is a small drum with AC brakes.
Posted: Sun Jul 27, 2025 6:20 pm
by Shrshot
Earlier diff. small drum with AC brakes. Everything is new except the housings.
Posted: Mon Jul 28, 2025 8:00 am
by Wingnut
You mention a 1919 engine, does it have the narrower transmission brake band then.
Posted: Mon Jul 28, 2025 2:43 pm
by Shrshot
Yes it does, and the early style pedals too. The brake band is still hooked up, but I backed off the adjustment when I added the AC brakes. This way the wheel brakes do the stopping. The trans band will apply should the AC brakes fail. The brake cam will apply the band when the pedal is almost to the floor as a safety.
Re: 26 Tudor For Sale "PRICE LOWERED"
Posted: Sat Aug 02, 2025 10:03 am
by Shrshot
Price lowered $8000 or best reasonable offer. I hate to part with it, but really need the garage space.
Posted: Mon Aug 18, 2025 3:40 pm
by Shrshot
To The Top...
