Open Valve Block
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Open Valve Block
Post by ThreePedalTapDancer » Fri Apr 16, 2021 6:23 am
Not for the wallet shy individual, but If you are need one, here you go. As seen on Tbay.
https://www.ebay.com/itm/Model-T-Ford-1 ... Sw6bpgdxti
Last Name: Hatch
MTFCA Number: 49974
Re: Open Valve Block
Post by Dan Hatch » Fri Apr 16, 2021 9:30 am
Thanks good to know.
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Fri Apr 16, 2021 11:52 am
a 1300 higher number than my 1910 Touring./ Did anyone look up what to see this came out of? Has the original timer plate and original timer. There are a few 1910s out there with later engines. This would be a good fit for a 1910 that needs the correct block.
richc
First Name: Rich
Last Name: Chillingworth
MTFCA Number: 30527
MTFCI Number: 23207
Post by richc » Fri Apr 16, 2021 1:21 pm
The block appears to be the one Charlie Shaver had as part of his 1910 project car.
Rich C.
