UPDATE ! Ruckstell fiber washers
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Apr 25, 2021 2:27 pm
5-8 update !! I have 3 of these left. I found another small sheet, so can make about 10 more, but will not do so unless there is a need. Tmorsher@icloud.com to reach me.
What would Glover do? No more big projects around here so decided to have wifey convert my coveted really old red fiber material into washers. She just don’t know it yet! This stuff wears like the hobs of hell, but you need to decide. If you want a machined washer .115 thick, $25 ppd to you. TAKE A GOOD LOOK AT WHAT IM OFFERING. DIMENSIONS ARE SHOWN, THE I.D. IS 1.810, the OD is 3 7/8. No other holes. I’m not interested in getting in that debate. If you need to machine your P-159 bell a bit to clean it up, I can send you two that are .060 thick, for $35 ppd. Save some $$ on multiple purchases as $5 of that is postage. VERY LIMITED SUPPLY Tmorsher@icloud.com is the only way to take care of THANKS !
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Ruckstell fiber washers
Post by CudaMan » Sun Apr 25, 2021 4:34 pm
Excellent! I just sent you an email. :)
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sun Apr 25, 2021 6:12 pm
Hi Tim: I'll take one of the .115 washers. I'll need to top up the mailing fees. Let me know how much. Thanks : Bruce
Plankhill
First Name: Brendan
Last Name: Doughty
MTFCA Number: 15143
Post by Plankhill » Mon Apr 26, 2021 5:34 am
Tim
I will take a .115. Will get a check in the mail to you.
Brendan Doughty
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Mon Apr 26, 2021 7:05 am
Tim, I would like one of the .115 washers. A couple of questions: what is the reference cited in your post? My bell is new, so is the Ford steel piece also .115 thick, making the fiber one a direct replacement? And what is a hob? Email coming. Cheers, Bill
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Mon Apr 26, 2021 9:23 am
Tim, I've emailed (direct reply) several times this morning. Everytime I have received an 'undeliverable/address not found auto reply'.
If you have a spare 3.5" crank pulley pin, add that to my order before you ship. My pin threw yesterday :(
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon Apr 26, 2021 12:12 pm
There are three or four slots in the P-159 bell that allow for checking clearance with a pointed feeler gauge. I have installed a standard steel Ford washer in there, and then determined the additional clearance needed to give a proper fit. I then remove the steel washer, and install the fiber washer of the proper thickness to do the job, and allow for clearance. At the moment I'm thinking of having some made. Haven't made any plans yet.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Apr 26, 2021 12:35 pm
Ryan, I’ll look , but don’t think so. I use dan MCeachern pulleys in all my rides. Set and forget! Bill, a hob, or hub is the thing in a fireplace where you hang the pots. So if something is hotter or harder than hubs ( or hobs) of hell, that means they are fire tested, and hard,hard,hard. As for the attribution, a good friend sent it to me. I’ll check with him. As for red fiber, It may be good to read up on vulcanized paper. This was invented in the 1880s ( I think) and was made and used for decades in industry, exactly for this use, and for a very good electrical insulator.
I have a NOS ruckstell under my car and it has original red fiber in it.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Apr 26, 2021 3:52 pm
Bill Hoffer, et al. It’s on page 10 of Glover Ruckstell’s install instruction manual.
Dropacent
Last Name: Morsher
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon Apr 26, 2021 3:59 pm
I failed to mention, I'm going to drill the two holes for the dowel pins, although it isn't necessary.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Apr 26, 2021 6:14 pm
I also failed to mention, I’m not
Dropacent
Last Name: Morsher
Re: UPDATE ! Ruckstell fiber washers
Post by Dropacent » Tue Apr 27, 2021 11:16 am
Back to top. 10 sold, I only have 10 left
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Apr 27, 2021 12:42 pm
Please send me off a couple Tim.
MTFCA Number: 14383
Post by speedytinc » Tue Apr 27, 2021 1:25 pm
Please excuse a stupid question. 1.062 i.d.?? thats axle diameter. Shouldnt it be 1.812" i.d. : diameter of the axle gear?.
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Apr 27, 2021 1:52 pm
Thanks John, I corrected it. I’ve heard the saying, “there is no such thing as a stupid question” I happen to disagree with that, but that’s beside the point. Thanks for the correction. I’m leaving them a tad undersize on the ID for wear. They can be opened up a bit if needed by sanding them. In my opinion, they should revolve freely, but you what they say about opinions. That’s a saying I agree with !
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Tue Apr 27, 2021 8:36 pm
I have no skin in the game as to whether or not the trust washer should be fiber or hardened steel, or whether or not it should have holes in it out not. I do want to share a patent drawing for a Glover Ruckstells' version of the two speed rear end. A quick history lesson, Glover did not invent the rear end, the forerunner was the “Perfecto Axle,” designed by Arthur Baker. The patent drawing (which often are often notoriously incorrect), interestingly shows the trust washer combined with a "bushing" for the axle gear. The combination is held in place (from rotating) by the small pins. So here is an example of a hardened steel trust washer/bushing with holes being used. Granted the patent drawing may not reflect how the axle eventually got built or improvements in its' life span. So draw your own conclusion. Enjoy
Always looking for vintage Whizzer engines, bikes & parts. What do you have?
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Apr 27, 2021 8:52 pm
Bushing in yellow highlite
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Apr 27, 2021 8:58 pm
The dark blue is where ford washer would be placed,showing gaps
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Apr 27, 2021 9:04 pm
This is where the red fiber will be located, right up to bearing surface of axle gear, no gap. It’s also important to note, when ruckstells patent was drawn , the Ford differential housing still perhaps had the bronze bushing installed to ride on axle gear surface. This bronze bushing was eliminated at some point in time. A lot of original ruckstell housings have been rebuilt in this exact area over time, or should have been. Perhaps fixing it with a bronze T shaped bushing at that point would be a good repair.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Tue Apr 27, 2021 9:29 pm
Don't read into the fact that there is no "gap", again patent drawings aren't meant to "share" all the construction details, only enough to support the "claims". The patent that this drawing is from is a "cushioned change speed axle" meant to absorb some of the shock to the component parts during hard shifting. Filed in 1924 and issued in 1925.
rgould1910
Last Name: Gould
Post by rgould1910 » Tue Apr 27, 2021 10:01 pm
The red fibre fits between the inner surface of the large bell housing and the outer surface of the differential carrier. The axle gear shoulder rides against the inner surface of the differential carrier and never comes in contact with the red fibre washer.
An interesting evolutionary tidbit. Re your comment about using a bronze T shaped bushing as a repair when there is too much slop in the hole in the bell housing, Tim, on Perfectos a flange or T bushing is pressed into the large bell housing and the flange part plays the same role as the fibre washer.😀
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Apr 28, 2021 12:17 am
I’m not pushing one method of rebuild or recondition over another. I’m reading NOTHING at all in the patent drawings. I’m fully aware patent drawings can range from exact blueprints, to very vague concepts and anywhere in between. ...... I’m simply using the patent drawing you posted as a vehicle for pointing out where this simple red fiber washer , made of old school original vulcanized paper stock of the correct thickness as the original was, will be installed, compared to installing a steel FORD washer there, held in place with pins. I do believe, however, the red washer WILL touch the axle gear hub. In my opinion, it should be a loose fit, but also my opinion, it should be a much better fit than the FORD washer provides( which the ORIGINAL ruckstell manual mentions specifically NOT to use ! ) I did this because I’ve rec’d a number of private emails wondering where this washer is supposed to go . As Richard notes, the Perfecto used a similar bushing setup to ruckstells patent drawing. Richard has restored several Perfectos, and I believe wrote an article on same. This is where Original Smith can point out again, if he feels necessary, that he is drilling two holes for pins but not using the pins. Hurrah! Everybody can make up their own mind , and I’m also sure there are many ways to skin the cat. Maybe someone will check out using UHMWP for washers? That may be the better solution. I’m only responsible for what my hands touch.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Apr 28, 2021 10:55 am
I am drilling the two holes in the fiber washer, because that is how it was originally done! I only have one original used red fiber washer left. My advice to anyone considering using one of Tim's new washers is to check the clearance like I mentioned. .115" is .010" thicker than the original I have, which appears to have been .105" when new. There is a 1/16 ridge around the outside edge of the washer with no wear, and that is where I get the .105" from. Due to normal wear, .115" will probably be ok, but I would definitely check while assembling.
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Apr 28, 2021 3:08 pm
Bump to top. I have 6 of the .115 washers still available. I have plenty of the .060 washers, which may work even better, but you decide. Tmorsher@icloud.com to reach me. Thanks!
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Apr 28, 2021 3:17 pm
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Apr 29, 2021 12:43 pm
I really appreciate all the effort Tim has done for my original post. Thanks Tim! I pulled out a couple of spare P-159 bells, and they both have the dowel pins. I'll probably make some of these too, but haven't decided yet for sure. They will be the red fiber, and I'll probably drill the dowel pin holes too.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat May 08, 2021 6:46 pm
Bump to top update
fordgood1
First Name: Stephen
Last Name: Francois, Jr
MTFCA Number: 31406
Post by fordgood1 » Sat May 08, 2021 10:26 pm
Tim, please send me two of the washers and I'll remit $50. Please send me your address and I'll send the check ASAP.
fordgood1
First Name: Stephen
MTFCA Number: 31406
Post by fordgood1 » Sat May 08, 2021 10:37 pm
Tim, my email address is fordgood1@yahoo.com. Also. let me know what, if any, postage costs. Thanks.
