early brass horn
Topic author - Posts: 366
- Last Name: Rosenthal
early brass horn
WTB Early brass double twist horn with "scalloped style cover". Entire horn or cover with bell only. Must be restorable parts. Call 1 513 378-4235
- First Name: Eric
- Last Name: Edwards
- * REQUIRED* Type and Year of Model Ts owned: 1909 Town Car 1912 Touring
- MTFCI Number: 16
Re: early brass horn
I have a few reproduction double twists left but not with the scalloped screen. Eric Edwards
Still no activity per this request....hope someone here has this either complete or as parts. If interested in a trade, I have (2) double twist style horns with the standard bell cover and horizontal inlet...both are perfect show quality...one stamped RUBES, one with no stamping. Both are originals that I restored.
Not sure what the provenance of this style is, or precisely how long Ford was using them, although I don't believe I've seen one on a 1910 car. Never seen one that has a radial double twist tube like 1910 through 1912....all have a semi-rectangular wrap of the tube. Benson Ford has invoices showing (7) different horns having been supplied in 1909, however nothing describes exactly what the physical differences may have been. Perhaps someone here is in the know on this?
Regards,
Scott
Regards,
Scott
- First Name: Herb
- Last Name: Iffrig
Scott I sent you an email this morning.
Let me know if you got it.
Herb
Herb
Hi Herbie:
Not seeing it, but have a new computer that I'm still struggling with, so could be I don't have this dude set up correctly. I'm "srosenthal@fuse.net"
Regards,
Scott
Regards,
Scott
- First Name: Herb
- Last Name: Iffrig
I sent one first through the forum. Now I sent one privately.
Herb
Herb
- First Name: Michael
- Last Name: Hanson
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 Touring
- MTFCA Number: 30276
- MTFCI Number: 23468
- Board Member Since: 2011
Hi Scott. Attached are some photos of a 1909 touring I once had that has the horn you are looking for. The car, which was restored by Marv Roth, is now owned by Russ Furstnow.
In my search for a Sears horn, I will keep my eye out for your horn.
All the best,
Mike
All the best,
Mike
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Just curious, what does the Sears horn, you are looking for, look like? I assume fir a Sears car?
Wow Mike, that Sears pigtail horn is quite an arrangement. The scalloped horn on the 09 is the only one I've seen with the radial inlet tube...very cool, thanks for sharing these.
Regards,
Scott
Regards,
Scott
Apologies John T. I received your Email and thought I had sent a response,, but apparently did not, so resent this AM.
Regards,
Scott
Regards,
Scott
- Last Name: Hanson
Hi Scott. Found this original photo on eBay. Looks like the horn your looking for. Mike
Regards,
Scott
- First Name: Herb
- Last Name: Iffrig
Scott I sent you another email yesterday.
Herb
Herb
- Last Name: Hanson
Hi Scott. Left you a voicemail. Please see the following listing on eBay. Good luck!
Original Double Twist Rubes Brass Automobile Horn Ford Model T
Item number:393311429252
Kind regards,
Mike Hanson
Kind regards,
Mike Hanson
Hello Mike:
Got your message and will watch this auction. I hope you were the buyer who snagged the recent Sears Pigtail horn I saw on EBAY? Looks like a good part less missing only the mounting bracket.
Many thanks to the MTFCA Classifieds and a number of good folks here...leads and parts have netted restorable parts that may factor into a constructed horn. Still looking for a couple of minor pieces in better donor condition then I'll post photos of a finished product.
Regards,
Scott
Regards,
Scott
- Last Name: Hanson
Hi Scott. Wasn't me on the Sears horn...I already have two coming my way soon.
If you check the HCCA classifieds under an offering for Pierce Arrow lights, I think there is a restored horn like your looking for hiding in the lot.
Good luck,
Mike
Good luck,
Mike
Many thanks again gentlemen. I was able to get enough parts together to put this one together.
Regards, Scott
Regards, Scott
Regards, Scott
Regards, Scott
- First Name: Mike
- Last Name: Bird
Eye candy!
