Original 1912 or earlier 7 rivet engine pan, with the reinforcing plate under the seven arm rivets. Has been welded and repaired in the inner corners, decent work, will need to be dressed. Evidence of extra brazing evident around the arms, nose and various places, obviously very old reinforcing by previous owner. It has a brazed patch on the bottom of the hump, also done a very long time ago. It is still a very solid pan, no cancer or rust out evident. Just needs to have some of the welds and brazing cleaned up for appearance. Very hard to find pan. Can provide more detailed pictures if needed. Pick up required or arrange your own shipping. 500.00
Early 7 Rivet Engine Pan
Topic author - Posts: 1413
- First Name: Ed
- Last Name: Martin
- First Name: Michael
- Last Name: Abbott
- * REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
- MTFCA Number: 49918
Re: Early 7 Rivet Engine Pan
Email sent
Michael A
Michael A
- Last Name: Abbott
I’ll take it Ed once pictures confirm it’s all correct.
Thank you Michael A
Thank you Michael A
- Last Name: Abbott
Thanks Ed, your correct shipping is very high out of Idaho
Thank you for check this out for me much appreciated.
Good luck, the pan is very solid.
Regards Michael
Regards Michael
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
There was a nice one that sold at luray for 500.
- Last Name: Abbott
Thanks Joe
