5z197 rear spring perch 40.00
5Z210 flywheel cap screw 20.00
3z501 piston pin bolt 10.00
5z817 carb bolt wrench 20.00
5z152 rear axle housing 10.00
5z195 Ford tappet wrench 5.00
5z1834 ? 5.00
Band adjustment wrench 10.00
Waldon flywheel cap screw 15.00
Waldon #4 rod wrench 10.00
Kdmks AT att.net all plus shipping.
Ford service tools
Topic author - Posts: 1243
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
Re: Ford service tools
Would like to buy the rear spring perch wrench, please
email sent
email sent
NH Full Flow Float Valves
- First Name: Kim
Scott, sorry it was already sold. These are the tool I have left.
after you're done selling wrenches, do you mind if I use your photo for a "want ad" for a perch nut wrench, in a few days?
thank you.
thank you.
- First Name: Kim
No problem, that's the only one I've ever had.
