Flywheel Balance Jig FS
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat May 08, 2021 10:53 am
Here is a surplus to me flywheel balance jig. Can be also used to balance crankshaft grinder wheels. Heck you can balance anything you can put on it. Can bring to Luray But ONLY if Sold. Email me at address in pictures. Thanks Dan
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Re: Flywheel Balance Jig FS
Post by BE_ZERO_BE » Sat May 08, 2021 11:17 am
email sent
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat May 08, 2021 11:37 am
Still available 😊
Be_Zero_Be
Rich Huggins
First Name: Rich
Last Name: Huggins
MTFCA Number: 50661
Post by Rich Huggins » Sat May 08, 2021 11:55 am
How much and can you ship
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat May 08, 2021 12:20 pm
I will take $700 you pickup at Luray or here.
Here is one like it on eBay check it out
https://www.ebay.com/itm/274616413396
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun May 09, 2021 7:28 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 12, 2021 4:13 am
Can also bring to Hershey
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun May 16, 2021 5:57 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 18, 2021 6:46 pm
Back to the top
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Tue May 18, 2021 8:12 pm
This Is a serious tool. I have been Balancing Cranks, Flywheels an Transmission Drums for over 50 Years with One just like Dan's. I have never had a customer question or complain about a vibration on any motor or transmission that I've done since I started to Balance with mine.
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Tue May 18, 2021 8:20 pm
My Balancing setup.
First Name: John T
Last Name: Tannehill III
MTFCA Number: 49460
Post by JTT3 » Tue May 18, 2021 10:09 pm
Dan & Bill how is the flywheel balance? On the crank or alone by itself. If together how is it counterweighted? If by it’s self how is the fly wheel mounted? Thanks for the info on the neat jig.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 18, 2021 11:17 pm
I first balance the triple gears, then put them on their pins, mount the flywheel on arbor. Flywheel on to stand, find heavy side and remove weight till balanced by same way Ford did drill bit.
First Name: John T
MTFCA Number: 49460
Post by JTT3 » Wed May 19, 2021 12:30 am
Perfect sense, thanks Dan.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed May 19, 2021 11:07 pm
I heard that you cannot use a a static balancer to balance a crankshaft. Fine for flywheels and drums. My experience is to dynamically balance the crank. Then assemble the flywheel and trans shaft as they will run in the car and dynamically balance the flywheel as attached to the crank and trans shaft. I have a very smooth running 10 touring car balanced that way. The triple gears were weight balanced, the drums dynamically balanced. The brake drum and diving plate were balanced as a unit. Again as they were to run in the car. I did the same on a 12 roadster and a 27 roadster. The difference is very noticable.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun May 23, 2021 7:43 pm
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 26, 2021 7:38 pm
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat May 29, 2021 7:04 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Jun 04, 2021 9:08 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun Jun 06, 2021 7:19 pm
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue Jun 08, 2021 5:22 am
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Jun 18, 2021 2:53 pm
Back to the top
JacolbEdwards
First Name: Jacolb
Last Name: Edwards
MTFCA Number: 50281
Post by JacolbEdwards » Sun Jun 20, 2021 10:07 pm
Rgould1910 The Ford crank rods and mains come in at 1.2485 … It is a bent piece of rebar at best even static balanced with brake drum low speed and drive plate is a massive improvement from how Henry built them
JacolbEdwards
First Name: Jacolb
Last Name: Edwards
MTFCA Number: 50281
Post by JacolbEdwards » Sun Jun 20, 2021 10:14 pm
Haha can’t forget reverse drum
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Mon Jun 21, 2021 6:34 am
And if you want a real joke, the holes drilled in Model A cranks are just holes. The employees were treated like crap, so they went thru the motion of balancing. Never seen one balanced from the factory.
Just Sayin'
And I am still baffled that this jig has not sold..., Uhmmm.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Mon Jun 21, 2021 6:47 am
Dan,
Give me a call later, I will buy it so when I do sell all my Model T tools as a complete working shop it has it!
