FS: Warford Transmission for TT reduced $300
Topic author - Posts: 277
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
- MTFCA Number: 31221
Warford transmission for TT trucks. Rotates freely and smoothly. Got it from a TT guy back in 1983. Dad and I were going to put together a TT but he passed away shortly thereafter. Needless to say the project ceased. I would like $300 or best reasonable offer plus shipping. 9 photos will be attached, if not, will resend another posting. Thank you.
- MTFCA Number: 52564
Re: FS: Warford Transmission for TT
Click on the pencil and add more photos here, you can do 5 per post. Submit that after doing a preview to check they are loaded. Then add the next 3 or 4 as a reply to the first message. Don't need to start a new listing to add photos, they get lost that way. The pencil is in the message box over on the right top.
1920 Dodge touring
1920 Dodge touring
- First Name: jay
Thanks Mark. My problem was that the original files were too large. I've resized and posted successfully.Mark Gregush wrote: ↑Sun Sep 19, 2021 9:39 pmClick on the pencil and add more photos here, you can do 5 per post. Submit that after doing a preview to check they are loaded. Then add the next 3 or 4 as a reply to the first message. Don't need to start a new listing to add photos, they get lost that way. The pencil is in the message box over on the right top.
- First Name: DAN
- Last Name: MCEACHERN
You may be missing a few pieces- the front adapter that goes between the Warford trans and the rear of the engine- looks like a 5" long drive shaft tube with the ball and flange on it. 2nd important piece is the rear crossmember for the Warford.
- First Name: Terry & Sharon
- Last Name: Miller
- MTFCA Number: 32583
I have 2 Warford adapters for sale, so don't let that be a deal killer.
Terry
Terry
- First Name: jay
Thank you for the information regarding the other parts. I'll look through the boxes for these parts.
- First Name: Jan
- Last Name: Kure7876
Re: FS: Warford Transmission for TT reduced $300
Hello, I like your gearbox and would like to buy one. Is it still valid?
Thank you.
John
Thank you.
John
