turtle deck key, drag link and more NOS
Topic author - Posts: 1198
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
For Sale: Turtle deck key $7
coil mounting bracket 12/27 $2.50
differential thrust washer with oil grooves on both sides. Brass $13 each
drag link 09/10 $200
steering gear rod ball cap 09/27 $12
front dust cap assembly 09/27 $13.50
crankshaft front seal. felt 2 pcs. 9/27 1.50 each
oil drain plug 13/27 $3
all plus postage
all plus postage
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- MTFCA Number: 49471
- Board Member Since: 2012
Re: turtle deck key, drag link and more
Melba,
There are many different drag links and must not be misfitted. What is the length of the one you have. Is the socket tight to a 1" ball? Are the threads clear and sharp? If yours is 30 3/4" and the rest is as described above, please write to me.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
- First Name: Melba
- Last Name: Nolan
Re: turtle deck key, drag link and more NOS
are you measuring just the rod or end caps
- First Name: Ken
- Last Name: Buhler
Just the rod. Be careful to get an accurate measurement. Please send me your number privately and I will call you.
Thank you,
Ken
Thank you,
Ken
Work honestly
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
- MTFCA Number: 50228
PM sent for Turtle deck key
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
John
Martin, Ohio
- First Name: Melba
- Last Name: Nolan
turtle deck key sold
- First Name: Melba
- Last Name: Nolan
move to top
