Wanted Stromberg O-F carb
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
MTFCA Number: 52588
Post by BUSHMIKE » Sun Nov 27, 2022 8:37 am
Like the title says….I am looking for a nice rebuilt Stromberg OF for my TT.
MTFCA Number: 52564
Re: Wanted Stromberg O-F carb
Post by Mark Gregush » Tue Nov 29, 2022 11:04 am
I see you want a rebuilt one but just sent you an email with link to one on eBay. I just noticed the one on eBay is missing both needles.
There is also this one;
https://www.ebay.com/itm/295372854184?h ... 000%7C7000
1920 Dodge touring
Post by Scott_Conger » Tue Nov 29, 2022 12:01 pm
Mark
that OF missing the slow/fast needles is for a Willys. It is not a "T" carb, though it will be confused as one by most everyone who looks.
once it gets a new set of these, it will be complete, but there are so few Willys folks around, who knows?
NH Full Flow Float Valves
MTFCA Number: 52564
Post by Mark Gregush » Tue Nov 29, 2022 5:23 pm
My understanding is the "OF" was only made for Fords. How can you tell it is for a Willys not a Ford?
1920 Dodge touring
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Nov 29, 2022 5:28 pm
https://www.mtfca.com/discus/messages/4 ... 1412643388
Post by Scott_Conger » Tue Nov 29, 2022 6:03 pm
Mark
Ed has clearly shown the difference on the casting machining. Also, look at his upper picture and see that the Willys throttle arm has a "crink" in it to shorten it and change the throttle input geometry to adapt to a shorter input.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Nov 29, 2022 6:27 pm
The E-Bay link to the OF above has "Studebaker" on the float bowl cover ?
Post by Scott_Conger » Tue Nov 29, 2022 7:53 pm
Steve
After the glass bowl era, Strombergs generally all take the same float bowl cover (either cast or sheet metal depending on vintage).
The OE-1 Was a Studebaker carb and that cover would have come on it. Insofar as they are interchangeable, it migrated onto a Willys carb, apparently.
Right now, Ed Martin is selling a Stromberg LF which sports the cast version of the cover if you want to check his ad for comparison: https://mtfca.com/phpBB3/viewtopic.php?f=5&t=32931
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Nov 29, 2022 9:50 pm
Thanks Scott - education always appreciated !
MTFCA Number: 52564
Post by Mark Gregush » Wed Nov 30, 2022 12:27 am
Thank you Scott and Ed. Guess you could plug and redrill the mounting holes.
1920 Dodge touring
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Wed Nov 30, 2022 12:53 am
That's my auction listing. Indeed, that carburetor is almost certainly off a Willys-Overland Light Four, Model 91, 92, or Redbird. Stromberg the OF (and later the RF) for both Ford and Overland. Stromberg supplied Willys-Knight with either an OD-1 or an OS-2 depending on year.
The float bowl cover says "Studebaker model" because that was the cleanest spare one I had on hand. All of the O and O-related float covers and floats interchange except the OTs. Studebaker Light Sixes used the "Studebaker model" OE-1, but they were sold as OEM or aftermarket for a lot of cars.
I'll add to the auction description.
Schrep771
Last Name: Schreppel
* REQUIRED* Type and Year of Model Ts owned: 1925 Tudor, 1915 Touring, 1913 Touring
MTFCA Number: 23085
Post by Schrep771 » Wed Nov 30, 2022 5:48 am
Mike,
Email Sent.
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
MTFCA Number: 373
MTFCI Number: 184
Post by JvanMaanen » Wed Nov 30, 2022 9:33 am
Mike, I have a Stan Howe rebuilt OF, sent you and email. Jim
BUSHMIKE
Last Name: Cushway
MTFCA Number: 52588
Post by BUSHMIKE » Wed Nov 30, 2022 9:46 am
Thank you all for info and leads. I had no idea these carbs brought the $$ that they do. For now, I am going to look for a cheaper alternative. Thank you.
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Thu Dec 01, 2022 12:58 am
What price range were you hoping to find one for? I know there are some guys still watching this.
1912 Torpedo Roadster
