6 volt Cutout -
BarnesvilleT
Topic author - Posts: 101
- First Name: William
- Last Name: Hallada
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
6 volt Cutout -
Thought it was a good one. Some posts have pointed out that it is no good. I have discarded it.
Re: 6 volt regulator
That is a cut-out - not a regulator - BIG difference !
Re: 6 volt Cutout
Thats one of them cheap generator killers. Throw it away or use it for a diode conversion.
They were $29 new.
They were $29 new.
Stu Tomlinson
- First Name: Stuart
- Last Name: Tomlinson
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
Re: 6 volt Cutout
i AGREE THIS IS A POOR MODERN PRODUCTION. DO NOT USE THIS. YOU WILL OVERHEAT YOUR GENERATOR AND RUIN A BATTERY.
BarnesvilleT
Re: 6 volt Cutout
It is in the garbage! Had no idea that it was that bad.
Dave Young
- Last Name: Young
Re: 6 volt Cutout -
Send the top can out to Jeff (Admin). He needs them to use in making the new VR’s. It’s much better than having it sit in a bucket in your shed and it helps our hobby.
Re: 6 volt Cutout -
Jeff was wanting "original" can tops - not repros - he's having new cans produced now.
Re: 6 volt Cutout -
Its good for a diode update (good insulation) & save as a spare.
